Noice in tranny when the A/C is on?
Old Jun 26, 2007 | 09:10 PM
HCivicSi23's Avatar
Default Noice in tranny when the A/C is on?
Every time the A/C is turned on, I get some type of clicking/knocking noise in the engine bay. When I traced the sound, it sounded like it was comming from the tranny? Any ideas?
Old Jun 26, 2007 | 09:11 PM
hmtcrxsir's Avatar
Default Re: Noice in tranny when the A/C is on? (HCivicSi23)
sounds like the AC pump/compressor is engaging?
Old Jun 26, 2007 | 09:12 PM
HCivicSi23's Avatar
Default Re: Noice in tranny when the A/C is on? (hmtcrxsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">sounds like the AC pump/compressor is engaging?</TD></TR></TABLE>
Old Jun 26, 2007 | 09:14 PM
RockinthEFhatch's Avatar
Sounds like it to me. The transmission has nothing to do with the AC at all...
Old Jun 26, 2007 | 09:20 PM
hmtcrxsir's Avatar
Default Re: Noice in tranny when the A/C is on? (RockinthEFhatch)
thats what i was thinking
Old Jun 26, 2007 | 09:23 PM
slowcivic2k's Avatar
If it only occurs when the compressor initially engages, that is normal, if the noise persists, see below.
The AC pump bearing may be going bad, there are two bearings, the freewheel bearing, which is the one it rides when the ac is off, and the actual compressor bearing. If it is audible when the compressor is on, you more than likely have a bad compressor bearing.
Old Jun 26, 2007 | 09:30 PM
HCivicSi23's Avatar
Default Re: Noice in tranny when the A/C is on? (slowcivic2k)
That makes more sense. I parked the car and put it in neutral with the A/C off and the the noise did not persist. When I turned the A/C on, thats when I heard the noise. Where are the two bearings loacted exactly?
Old Jun 26, 2007 | 09:31 PM
hmtcrxsir's Avatar
behind the pulley
Old Jun 26, 2007 | 09:32 PM
HCivicSi23's Avatar
The noise is comming from the tranny side of the engine bay though.
Old Jun 26, 2007 | 09:34 PM
hmtcrxsir's Avatar
maybe from your tranny? throwout bearing?
Old Jun 26, 2007 | 09:36 PM
HCivicSi23's Avatar
I doubt it. The noise is contolable and only exisits when the A/C is on.
Old Jun 26, 2007 | 09:37 PM
hmtcrxsir's Avatar
man its just your imagination. should be just the ac pump engaging. as long as everything is fine and in working order. fucck it.
Damon Reeves's Avatar
Are you sure it's your transmission?
If you have ever seen the lines for the a/c.....it has nothing to do with the transmission.
Old Jun 26, 2007 | 09:39 PM
HCivicSi23's Avatar
Haha no. Theres something up with the A/C. Ill just look into it, but thanks for the ideas though
Old Jun 26, 2007 | 09:40 PM
hmtcrxsir's Avatar
or better yet. lose the AC and free up some HP.
Old Jun 26, 2007 | 09:41 PM
HCivicSi23's Avatar
Default Re: Noice in tranny when the A/C is on? (Damon Reeves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Damon Reeves &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure it's your transmission?
Yea I know that, but The noise is only made when the A/C is on. It will immediatly stop when the A/C is turned off. I opened up the hood when the noise was bing made and it was a clear knocking noise on the left side of the engine bay. I am not saying its comming from the tranny itself, but that side of the engine bay.
Old Jun 26, 2007 | 10:39 PM
JarvisW's Avatar
Sol to Sol
make a homemade mechanics stethoscope.
I use my longest two 3/8th drive extensions, put together. Put one end on the transmission, the other on your ear, then put it on the compressor, keep moving it around till you can pinpoint what its really coming from.
Old Jun 26, 2007 | 11:49 PM
Default Re: Noice in tranny when the A/C is on? (JarvisW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">maybe from your tranny? throwout bearing?</TD></TR></TABLE>
Throwout bearings do not make that kind of noise, and if it did happen to make a sound, it would be when the clutch is pressed, not released, if you have ever taken a tranny apart you know that the release bearing sits on a rest on the input shaft.
Isolate the tranny by depressing the clutch and note any change in sound, hold it in for a good 10 secs so that the transmission stops turning completely, then let the clutch out, note the change in noise, if any. If you hear noise, odds are the bearings are worn/destroyed, and will require replacement bearings at the least.
jd101
Honda Civic (2001 - 2005)
May 14, 2015 04:36 AM
TheDonut
Mar 25, 2011 09:34 PM
99_red_si
Aug 31, 2007 01:49 PM
01-1293
Honda Civic (2006 - 2015)
10
Jul 19, 2006 02:02 AM
Rocks
Sep 14, 2004 11:25 AM
