98ex motor into 98 dx coupe??????
im going to be doing a 98 ex swap into a 96 dx coupe. i have been looking for answers to my questions but i cant find them so ill ask you guys.........
i have the wiring harness for the ex motor and everything else thats needed!
i was just wondering if it would be a straight plug and play swap? im pretty sure it is im just not sure about the wiring, but if i have the ex wiring harness and a complete ex motor, would'nt be a straight plug and play swap?
yes if you have the harness it will be a direct bolt in considering you have a 96 and the new motor is a 98 both being obd2a you will not need to convert the computer wiring harness you can just plug in the ex computer.
so if i have a d16y8 engine and engine harness to match i can plug it into the plugs at firewall and just plug up the 96 civic vtec ecu its a done deal??? i guess my main question is are the wires ran to the computer from the fire wall plugs with vtec lines and whatever else you need to run vtec, or am i gonna have to tap a wire somewhere into the ecu????
you will have to run the two wires for vtec and one wire for the knock sensor
here are the ECU pinouts https://honda-tech.com/zerothread?id=1440036
alpha_1
Mar 10, 2008 10:04 AM
dubzz24
Jan 25, 2008 11:43 AM
3dcivic
Apr 2, 2004 06:17 PM
Lynx
Oct 10, 2003 10:49 AM
boostedcivicsir
16
May 9, 2003 09:58 PM
