Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
3G (2004+) TL Brake Bleed sequence...
Old Jun 26, 2007 | 10:01 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default 3G (2004+) TL Brake Bleed sequence...
Can anybody with the OEM shop manual tell me the recommended sequence for bleeding the brakes of 04+ TL? The owners manual says to replace the brake fluid in your car every 3 years, but doesn't give you the details of what order to do it in...
BTW: That old myth of farthest-to-nearest wheel from the master cylinder doesn't apply to any Honda I've ever worked on. So I'm only looking actual info directly from the service manual...
Thanks!
Old Jun 26, 2007 | 12:16 PM
dragncivic's Avatar
Default Re: 3G (2004+) TL Brake Bleed sequence... (94eg!)
fl, fr, rr, rl......
Old Jul 2, 2007 | 07:56 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: 3G (dragncivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragncivic &raquo;</TD></TR><TR><TD CLASS="quote">fl, fr, rr, rl...... </TD></TR></TABLE>
Thanks. I also found that it is necessary to drive the car afterward and perform 2 ABS activated stops. If those result in a mushy pedal, it is necessary to re-bleed one more time as there was air trapped in the ABS system and the ABS stops cleared it out...
Here is a link to the procedure on AcuraZINE:
http://tl.acurazine.com/forums...18283
Old Aug 16, 2007 | 11:54 PM
thanglesungei's Avatar
Default Re: 3G (94eg!)
Hello,
Thanks for the info. Could you please advise whether the engine should be turned on or off while doing the bleeding !!! Sorry this du.. question, what does it mean by this "perform 2 ABS activated stops" and how could I do it.
Thanks again.
Old Aug 17, 2007 | 04:49 AM
dragncivic's Avatar
Default Re: 3G (thanglesungei)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thanglesungei &raquo;</TD></TR><TR><TD CLASS="quote">Hello,
Thanks again.</TD></TR></TABLE>
engine off... ABS activated stops are hard stops that activate the ABS system... in other words try to lock the brakes up...
Old Aug 17, 2007 | 06:01 AM
94eg!'s Avatar
#1 Super Guy
Loved
The idea is to cycle the fluid in the ABS system to move any possible trapped air back into the brake lines. If air did move into the brake lines, you would know after performing a couple abs stops because your brake pedal would suddenly be mushy and unresponsive.
DC_Legacy
Apr 16, 2009 10:18 AM
Minh826
Jul 21, 2008 04:14 PM
fso_BamBam
May 17, 2005 05:32 PM
TSAngry
Apr 27, 2005 05:01 PM
majeed11
Jun 30, 2003 08:06 AM
