ecu lights up............
Old Jun 6, 2002 | 01:29 PM
86CRXSi's Avatar
Default ecu lights up............
from the begining, my dash light comes on "PGM-FI", ok.......
find my ecu under pass side seat,
it has clear panel with "8421",
behind panel are four lights,
the last light, behind "1" is on ,
wut now...wut does it mean...........wut is wrong?????????
Old Jun 6, 2002 | 01:31 PM
FUP23's Avatar
New User
Default Re: ecu lights up............ (86CRXSi)
Im so confused with that. How many times does it blink ?? You said 4 ?
Old Jun 6, 2002 | 01:39 PM
86CRXSi's Avatar
Default Re: ecu lights up............ (Devin17)
there is no blinking, it is a small clear almost a window bout an inch wide and has " 8 2 4 1 ", with a single little red light behind each number. the light behind the " 1 " is lit up when the light comes on , on the dash " PGM-FI ".
that is a mouth full.........
Old Jun 6, 2002 | 01:48 PM
Urban Business
Guest
Posts: n/a
uhh what ecu is this
Old Jun 6, 2002 | 01:50 PM
dustin's Avatar
Default Re: ecu lights up............ (TorteX)
I'm going to go out on a limb and guess an 86 CRX Si Ecu.
Old Jun 6, 2002 | 01:54 PM
Urban Business
Guest
Posts: n/a
Default Re: ecu lights up............ (dustin)
thats a bad guess im going to say its from a k20
Old Jun 6, 2002 | 01:55 PM
dustin's Avatar
ahaha
Old Jun 6, 2002 | 02:17 PM
86CRXSi's Avatar
sorry my bad......first guy right .
stock ecu in my 86 crx si........please help...
Old Jun 6, 2002 | 02:24 PM
Sonny's Avatar
I have the Helms for that car at home. If you don't have an answer by tonight, IM me and I'll look it up for you.
Sonny
Old Jun 6, 2002 | 02:29 PM
86CRXSi's Avatar
Default Re: ecu lights up............ (Sonny)
thanks will do....i have just old Haynes manual.....no info at all.
Old Jun 6, 2002 | 06:04 PM
seekerONE's Avatar
the "PGM-FI" light comes on and goes out=no problem
the "PGM-FI" light comes on and stays on=currently encounter problem
but if the light was on and later off then a code should be stored
here is how to read the codes from this computer
first of all there is no flashing leds
and only a single code is stored at any time
there are four leds each with a number 1,2,4, and 8.
the code is the number under the lit led
if more than one led is lit en add the numbers together to get the code
example
if led 1 is lit code is code1=02 sensor
if led1, led2, and led 4 are lit then code is code 7=coolant temp sensor
for a list of codes and what they mean
http://www.hybrid-k.com/tech/codes.html
the easiest way to clear the code is to disconnect the battery for a minute then reconnect
[Modified by seekerONE, 3:10 AM 6/7/2002]
[Modified by seekerONE, 3:11 AM 6/7/2002]
Old Jun 6, 2002 | 06:18 PM
FredoTheChimp's Avatar
maybe honda built a k20 crx for the fun of it, and he got luck
89efhatchcrap
Jul 18, 2006 11:42 AM
delsolb16
15
Nov 20, 2005 06:16 PM
frostt3ch
10
Jun 22, 2003 11:09 AM
hybridb18
Mar 29, 2003 09:12 PM
