airbag light
i took my passenger seat out and triggered the airbag light.... dont ask why...
ummm anyone know how to turn it off....
i would hate to go to honda and pay some $$
ive heard of the paper clip method but i dont think that refers to my problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rishelle »</TD></TR><TR><TD CLASS="quote">i just unplugged the grey and yellow switches and took the seat out.... the airbag light is really bugging me :/</TD></TR></TABLE>
Unbolt the seatbelt unit from the seat itself, and just plug it back in to the yellow/gray plugs on the floor. You'll probably still need to clear the SRS unit, which requires jumping some pins with a paperclip.
so i just take out the yellow plug from under the steering wheel and complete the circut with a paperclip? then plug it back in?
im a little iffy on this... i dont want to be doin this and having the airbag hit me in the face and crack my windshield
EDIT :after i replugged the ones under the seat
The Yellow plug that needs to be reset should be under your dash, near the gas pedal.
See if these help:
http://www.honda-acura.net/for...43612
http://www.dubovsky.com/projects/srslight/
See if these help:
Great information here and in the links posted. I followed the one at dubovsky.com. The method worked for me on a 2004 Civic EX. I did not need a screwdriver or any tools to remove the panel below the steering wheel. The latches are twist-off.
I did not disconnect the battery, but I did make sure the key wasn't in the ignition when I disconnected the MES connector from the block. I used a paperclip to short. The timing is important. I didn't get it right my first run, I think because the paperclip didn't meet the contacts properly.
It is important to short the connector plug and not what it plugs into (i.e. don't short anything on the connector block). Also, when you are done, turn off the vehicle and then make sure you plug the connector back into the same place. The 2004 EX connector block has some vacant slots that are very similar to where the MES connector actually belongs.
square_1
Sep 27, 2008 09:26 AM
