cluster help 95 teg help
i have a 95 teg rs my cluster was messed up i bought a 98 gsr cluster everything seams to be working except fuel gauge is acting up.. says i have a full tank actualy more then full... bad cluster wires crossed? witch wires controll the fuel gauge?
when the tank is full it will show a little above the F. just drive around like normal, and just watch the gas needle behave as you put on miles. if you want, you can run it till empty and see where the needle goes, and just keep a 5 gallon jug of gas in the trunk. (not on a hot day)
ill see it marked a little more then half on the old cluster... it was messed up cuz last owner put indeglows then took them off all gauges were in accurate... is it a plug in type deal ?
its a little after the f sort of E---------F / < needle
pik of car
pik of car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blazinrola80 »</TD></TR><TR><TD CLASS="quote">so i just swap the green film sine im doing gsr into rs i dont need any srs...</TD></TR></TABLE>
Id suggest, as the link demonstrates, to swap the GSR gauges into the RS housing.
