cluster help 95 teg help
Old Jun 25, 2007 | 06:44 PM
blazinrola80's Avatar
Default cluster help 95 teg help
i have a 95 teg rs my cluster was messed up i bought a 98 gsr cluster everything seams to be working except fuel gauge is acting up.. says i have a full tank actualy more then full... bad cluster wires crossed? witch wires controll the fuel gauge?
Old Jun 25, 2007 | 06:47 PM
Blahblah718293's Avatar
Default Re: cluster help 95 teg help (blazinrola80)
when the tank is full it will show a little above the F. just drive around like normal, and just watch the gas needle behave as you put on miles. if you want, you can run it till empty and see where the needle goes, and just keep a 5 gallon jug of gas in the trunk. (not on a hot day)
Old Jun 25, 2007 | 06:57 PM
Default Re: cluster help 95 teg help (Blahblah718293)
ill see it marked a little more then half on the old cluster... it was messed up cuz last owner put indeglows then took them off all gauges were in accurate... is it a plug in type deal ?
its a little after the f sort of E---------F / < needle
pik of car
Old Jun 26, 2007 | 09:56 AM
BlueIntegraBoy's Avatar
Follow this procedure to remedy your problem
https://honda-tech.com/zerothread?id=1836281
Old Jun 26, 2007 | 10:10 AM
Default Re: cluster help 95 teg help (BlueIntegraBoy)
so i just swap the green film sine im doing gsr into rs i dont need any srs...
Old Jun 26, 2007 | 10:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blazinrola80 &raquo;</TD></TR><TR><TD CLASS="quote">so i just swap the green film sine im doing gsr into rs i dont need any srs...</TD></TR></TABLE>
Id suggest, as the link demonstrates, to swap the GSR gauges into the RS housing.
Old Jun 26, 2007 | 01:51 PM
ok yea i red it better now that im home on bigg screen.... ill do it tomorow ill keep u guys posted and thanks..
seth01tuner
Oct 19, 2014 05:19 PM
sixfourkiller
May 9, 2009 10:49 AM
roger93si
Feb 12, 2007 01:31 AM
oh-k
Sep 14, 2004 06:40 PM
spoon063
Mar 30, 2004 10:27 PM
