99 Si - valve type noise... Bent valve??
Old Jun 25, 2007 | 06:33 PM
I8ayellowcrayon's Avatar
Default 99 Si - valve type noise... Bent valve??
I recently picked up a 99 Si with a bolt on Drag turbo kit, completely stock motor. So I know its been beat on..
It has a horrible noise that sounded exactly like loose valve lash. So I checked the lash, and every valve was at least .002 loose. I set them at .007 I and E. The noise is STILL there.
So I adjusted the intake valves to .006 like other people have been saying, and now the noise is REALLY bad. I've never seen anything like this before, or heard that kind of noise before.
Anyone have any ideas??
Old Jun 25, 2007 | 06:36 PM
FastLife617's Avatar
Default Re: 99 Si - valve type noise... Bent valve?? (I8ayellowcrayon)
Did you do a compression test?
Old Jun 25, 2007 | 06:53 PM
Haven't yet. I have noticed that it does have a steady idle, but its only at 16" of vacuum... The most vacuum I've seen with the motor was right at 20" with closed throttle at higher RPM...
Old Jun 25, 2007 | 07:22 PM
Someone also suggested looking to see if a valve spring is broken??
Old Jun 26, 2007 | 05:47 AM
Anyone?
Old Jun 26, 2007 | 05:52 AM
97Ej6mike's Avatar
Try some lucasoil stabalizer, helped make my motor much quieter
That may help the situation.
Old Jun 26, 2007 | 10:47 AM
No offense, but I don't really think MMO or the Lucas stabilizer is going to help much, especially since the noise is now worse when I tightened the valve lash...
If nobody else has any better suggestions, then yeah I'll try the oil stabilizer, but I'd like to keep looking around...
Old Jun 26, 2007 | 10:52 AM
Marcpb443's Avatar
Default Re: (I8ayellowcrayon)
do a compression test..
Old Jun 26, 2007 | 10:53 AM
sageuvagony's Avatar
I thought that stabilizer stuff was bad? Just by reading those reviews with pics.. Many of you have read that review..
Old Jun 26, 2007 | 05:01 PM
2 - 170
3 - 150
4 - 149
No definite answers there... Those numbers make me sad though.
Old Jun 26, 2007 | 05:21 PM
MeanGreenMachine's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I8ayellowcrayon &raquo;</TD></TR><TR><TD CLASS="quote">1 - 173
2 - 170
3 - 150
4 - 149
No definite answers there... Those numbers make me sad though.</TD></TR></TABLE>
ouch........bad sign...
Old Jun 26, 2007 | 05:25 PM
But not really a sign of a bent valve.
Right now I'm worried about the noise, I can worry about the headgasket later.
Old Jun 26, 2007 | 05:27 PM
Default Re: (MeanGreenMachine)
those numbers are low but it doesn't seem to be a bent valve could be couple things time to crack that motor open
Old Jun 26, 2007 | 07:06 PM
Guineapig's Avatar
injectors?
Old Jun 26, 2007 | 07:07 PM
97Ej6mike's Avatar
Time for a motor rebuild
Old Jun 27, 2007 | 05:50 AM
The injectors are CRAZY loud, but its just one continuous noise, not 4 going at once. I spent a lot of time with the stethescope making sure it wasn't the injectors. If I unplug two injectors at a time, the noise is still there and just as loud.
Old Jun 27, 2007 | 06:33 AM
A friend suggested that I check out the lost motion assemblies... The symptoms sound the same as what I have, but I wanted to ask and see if anyone else knew...
Cold start in the morning, there is no noise at all. Once its been running for maybe a minute the noise is there, and it gets worse for the next few minutes, then its just a contstant loud noise... Does this sound like a LMA?
Old Jun 27, 2007 | 06:45 AM
xAgyex's Avatar
Man I have to probably do the same then...I havent checked my compression rate..but I have some weird *** idle issues, and my dam valves are loud, and the dame **** be leaking oil some where...have to check all that this weekend for sure.
Old Jun 27, 2007 | 10:55 AM
I checked the LMAs on my lunch break and two or three of them are HORRIBLY loose, I can push them down with my finger. I'll probably do a T belt/water pump and headgasket when I replace those as well. Pretty sure the new HG will solve my low compression on 3 and 4.
I'll update the post whether or not the LMAs fixed the noise. Thanks for all the help!!!!
deerman2701
Jan 6, 2012 06:54 PM
ArmaanOG
Apr 8, 2009 03:16 AM
B20BV
Dec 14, 2007 11:55 PM
B18C_EJ8
Jun 4, 2007 05:10 PM
larsoch
Sep 28, 2006 08:30 PM
