will a dx ecu run a d16z6?
Old Jun 25, 2007 | 03:41 PM
black0hatch's Avatar
Default will a dx ecu run a d16z6?
will it work? just need to move the car and i dont have a p28.
Old Jun 25, 2007 | 03:43 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: will a dx ecu run a d16z6? (black0hatch)
it will work fine for what you need it for.
Old Jun 25, 2007 | 03:52 PM
hybridmath's Avatar
Default Re: will a dx ecu run a d16z6? (ek forever guy)
the car will run fine even if you daily drive it you just wont have vtec which isnt a big loss in d series anyway
Old Jun 25, 2007 | 03:59 PM
Syndacate's Avatar
It'll run the car, your gas mileage won't be the best and neither will your power. Also, your VTEC won't work.
If you don't have a P28 you can get that OBD-I DX ECU chipped you can run a Z6 basemap and everything would work perfectly.
Old Jun 26, 2007 | 09:30 AM
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">It'll run the car, your gas mileage won't be the best and neither will your power. Also, your VTEC won't work.
If you don't have a P28 you can get that OBD-I DX ECU chipped you can run a Z6 basemap and everything would work perfectly.</TD></TR></TABLE>
but will this cost more then getting a p28? there expensive.
Old Jun 26, 2007 | 11:06 AM
ddd4114's Avatar
Default Re: (black0hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black0hatch &raquo;</TD></TR><TR><TD CLASS="quote">but will this cost more then getting a p28? there expensive.</TD></TR></TABLE>
It will probably be cheaper.
Old Jun 26, 2007 | 12:14 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">If you don't have a P28 you can get that OBD-I DX ECU chipped you can run a Z6 basemap and everything would work perfectly.</TD></TR></TABLE>
be careful how you use that term, "chipped" usually refers to the simple conversion to an external set of fuel/ign maps.
what you'd need is to "chip" it AND add the VTEC components.
(for now, until some of the versions of software out there get more of the bugs worked out)
OP - it would still be cheaper than a P28.
88HATCH(:
Engine Management and Tuning
Jul 15, 2010 08:19 AM
Untamed_Hatred
Jan 29, 2008 05:02 PM
ef9i@asia.com
Jun 25, 2006 06:33 PM
VTECR021
Mar 7, 2004 09:21 PM
SpdFrk
Nov 28, 2003 02:06 PM
