Click sound and it won't start...
Old Jun 25, 2007 | 01:43 PM
KnuckleZ's Avatar
Default Click sound and it won't start...
Hey guys, I have a B18C5 in a 97 LS and I get a click sound and nothing. I already checked the battery and starter and everything's good. My check engine light comes up so the ECU is powered and I can actually hear de fuel pump. The engine doesn't crank at all. Anybody else with the same problem? Any help will be greatly appreciated. Thanx.
Old Jun 25, 2007 | 01:44 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: Click sound and it won't start... (KnuckleZ)
if the battery and starter are good and its not turning over, the only other thing i can think of is you seized your motor
Old Jun 25, 2007 | 01:48 PM
wearedaughters's Avatar
Default Re: Click sound and it won't start... (St Jimmy)
Check your battery cable connections. Mine did the same thing and it ended being a corroded terminal.
Old Jun 25, 2007 | 01:49 PM
KnuckleZ's Avatar
The car actually runs. It will start after a couple of tries. I drive the car everyday and it runs perfectly fine.
Old Jun 25, 2007 | 01:50 PM
toshiro's Avatar
I bent my Wookiee
Starter solenoid?
Same thing happened to my car, so I went old school and hit the starter with a pipe wrench. Now it starts every time. Not even joking.
KnuckleZ's Avatar
Default Re: Click sound and it won't start... (wearedaughters)
My battery terminals are clean.
Old Jun 25, 2007 | 01:51 PM
KnuckleZ's Avatar
Default Re: (toshiro)
I just bought a new starter and nothing. I get the same thing.
Old Jun 25, 2007 | 01:53 PM
toshiro's Avatar
I bent my Wookiee
When did it die? Did something happen the last time it worked?
Old Jun 25, 2007 | 01:57 PM
KnuckleZ's Avatar
The starter is brand new. I just bought it today and installed the damn thing and nothing. It's still doing the same thing it did with the old one.
Old Jun 25, 2007 | 02:05 PM
toshiro's Avatar
I bent my Wookiee
I meant the car, not the starter. Did the car run before you did something? Is this a brand new swap?
Old Jun 25, 2007 | 02:33 PM
KnuckleZ's Avatar
It's not a brand new swap. It was working fine. I changed the clutch a while ago but I checked the ground from the tranny and it's clean and properly grounded.
96H4TCH
13
Apr 24, 2020 01:39 PM
jgett002
Aug 3, 2016 02:00 PM
NightHawk92
Jan 9, 2015 08:06 AM
inaety
Jun 24, 2011 12:57 AM
Nicks95GSR
Apr 25, 2007 11:42 AM
