Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Squeeking clutch pedal
Old Jun 25, 2007 | 01:32 PM
CrazycakesEM2's Avatar
Default Squeeking clutch pedal
So lately whenever I slowly let the clutch out, like from a stop it makes this aweful squeeling sound. I've tried greasing the pedal with white lith and it helped for like a minute. The pedal still travels smoothly so I dont think its the master cylinder or anything. Anyone had this and fixed it???
Old Jun 25, 2007 | 01:34 PM
Boilermaker1's Avatar
its the ball joint on the end of the fork. on the front of the tranny, there's a boot with a slot in it. inside there is the ball joint.... grease it with something high temp. The honda dealer used the Odyssey sliding door grease on mine and its been fine for years.
Old Jun 25, 2007 | 01:51 PM
Default Re: (Boilermaker1)
I will check this out aswell, butit realy seems like the noise is coming from inside the vehicle. I thought it was maybe the return spring but greasing that doesnt help to much.
Old Jun 25, 2007 | 03:20 PM
s13_240sx_92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 &raquo;</TD></TR><TR><TD CLASS="quote">"Odyssey sliding door grease" .</TD></TR></TABLE>
AHHH HHHA! shin et su grease... this stuff is like the astroglide of the honda world.
Old Jun 28, 2007 | 07:57 PM
uneekvisions's Avatar
I'm having this same problem, my dealer is telling me it's going to cost like 90 bucks to take care of it??
Old Jun 29, 2007 | 05:30 AM
jimmypol's Avatar
I'm also facing this issue. Based on your answer, do you have to bring down the tranny to do so?
Old Jun 29, 2007 | 05:46 AM
Default Re: (jimmypol)
I tried to grease the spot where the slave cylinder pushes on the cluth fork with little success. It is very hard to pull that boot back and get a second hand in there to grease it. However Boiler was right (partialy) I was getting an aweful noise from there but I am also getting a squeeking from down by the cluth pedal/ maybe master cylinder (lets freakin hope its not that). If anybody gets this problem fixed let me know.
Old Jun 29, 2007 | 05:51 AM
devani's Avatar
http://www.civicforums.com/for....html
Follow the link...do this and you will be good in less than 20min..
pics are there too..
for the lazy, its removing two screws and clean and grease it...
Old Jul 1, 2007 | 05:14 AM
anonnonator's Avatar
i got that same annoying squeeking. lol.
Old Jul 1, 2007 | 10:15 AM
jimmypol's Avatar
Default Re: (devani)
Thanks
Old Jul 14, 2007 | 01:07 AM
noidg101's Avatar
I also had a squeeking noise coming from my clutch. Im going to add hi temp greese.
Upon dissassembly I found that my flywheel was cracked at three points where pilot bearing lines up....causing assembly to rattle.....
any questions please reply...
I origanily thought that it was my throw out bearing... but found out that it was cracked flywheel.....lol...whomp....whomp...........whomp. ...
Old Jul 20, 2007 | 11:07 PM
2wir3d's Avatar
Default Re: Squeeking clutch pedal (CrazycakesEM2)
i to have had this same problem. im glad you brought this up and i will get into it as well.
Old Jul 21, 2007 | 08:32 PM
hondaciv5's Avatar
i had the same problem on my 05 coupe...only has 30k on it but wen ever i pushed in the clutch it wuld squeek a bit..i took it to the dealer and the had to replace the clutch master cylinder?....warranty coverd tho
JDM B16A
Mar 23, 2006 02:08 PM
ep3 love
29
Oct 14, 2005 07:15 PM
honda97sol
Jun 19, 2005 12:59 AM
Johnny Gasparini
May 27, 2005 06:55 PM
cjohnson_2
May 9, 2003 02:31 PM
