I want to put my OBD1 B18A1 into my 93 EG and I dont know what mounts to use can someone help me
Old Jun 25, 2007 | 08:25 AM
averyvm's Avatar
Default I want to put my OBD1 B18A1 into my 93 EG and I dont know what mounts to use can someone help me
I have B18a1 engine that I want to put into my eg but I dont know what mounts to use
Old Jun 25, 2007 | 08:34 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: I want to put my OBD1 B18A1 into my 93 EG and I dont know what mounts to use can someone help me
https://honda-tech.com/zerothread?id=983454
Old Jun 25, 2007 | 08:51 AM
averyvm's Avatar
I have already been to that site. but after reading It i was still confused
Old Jun 25, 2007 | 08:57 AM
cute little bastard
ok well basically you can use all the integra mounts but on the driver's side mount, it depends if its a 2 bolt design or a 3 bolt design on the bracket. torque mounts are virtually the same, you can use the stock rear mount and the tranny side use the integra
Old Jun 25, 2007 | 09:05 AM
daluv's Avatar
This should help. Its a photo write up I did for mustang5.slow.
Old Jun 25, 2007 | 09:09 AM
averyvm's Avatar
on the driver side it uses three bolts to bolt the bracket to the bare block. is that what ur talking about. If I send some picks would that help
Old Jun 25, 2007 | 09:16 AM
daluv's Avatar
yes.
Old Jun 25, 2007 | 09:26 AM
averyvm's Avatar
other people have told me that I need to change the rear mount. Or were they talkin about the bracket
Old Jun 25, 2007 | 10:27 AM
daluv's Avatar
If you read my side notes concerning the rear mount, your question will be answered. Leave the black bracket on the drivers side of the block alone. You do not need to change that. The mount and bracket are two different parts, they do not need to both be changed. Just the mount. Do not take the bracket off of your block.
Old Jun 25, 2007 | 10:32 AM
daluv's Avatar
See the two nuts on the drivers side mount? Those bolts that they are attatched to are attatched to the drivers side bracket. All you need to do is take those two nuts off, take the motor mount bolt out (the one that connects the motor to the frame) then replace the mount, put the mount bolt back in, put the mount over the two bolts coming out of the block bracket, and put the nuts back on.
Old Jun 25, 2007 | 11:26 AM
projectTeG's Avatar
i believe you use the dc integra mounts.
Old Jun 25, 2007 | 11:28 AM
Damon Reeves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=983454</TD></TR></TABLE>
Word.
anzh86
Jul 23, 2010 09:20 PM
91DA9B16A
Jul 23, 2009 03:30 PM
RustyE.G.
Sep 3, 2007 05:14 PM
CW96
Dec 6, 2003 03:58 PM
d15Beta
Aug 25, 2003 05:50 PM
