engine stalls when... (I've read all 34 search results)
I have a 93 civic hb p30 ecu.
just built from scratch ls/vtec all new bearings, rings and headgasket
used my know working b16 head never remove intake mani or fuel rail or TB or iac.
running ls crank and rods w/ p30 pistons so my compression ratio is approx 12.2:1
I have a wideband and it reads 14.5 at idle or when returning to idle from a cruising speed.
fuel pressure is 55 psi @wot and returns to 42 psi @idle.
cannot find any vacuum leaks so far.
I used one heat range colder plugs due to the compression.
engine idles just fine @ 750 rpm timing is 16 deg btc.
when coming to a stop w/ clutch in or out and pressing the brakes veh will stall.
will restart w/o a problem and never runs rough at idle.
any suggestions are appreciated
changed iac, still stalls. changed tps and verified .5 volts @idle and 4.5 wot, still stall.
new cap and rotor still stalls. verified cam timing and check valve lash, still stalls.
HELP
HELP
welcome to the ******* club
https://honda-tech.com/zerothread/1975745
huge pain in the ***...isnt it?
i had the same issue on my car. changed out the throttle body and intake manifold all sensors, injectors, fuel rail, fpr and it fixed my problem.
i know this doesnt really pinpoint the cause for you, since i replaced all at one time i dont know which one fixed it, but i hope it will help point you in some sort of direction to solve your problem
the thing is that is the part of the car that didnt change when the new engine was built.
that all stayed the same. I just changed the block from a b16 to a 12.2:1 ls.
the only thing that would make that happen would be the iac valve not compensating for the power brakes,and i know if your booster check valve, or booster is not working properly it ill do the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sloshy »</TD></TR><TR><TD CLASS="quote">the only thing that would make that happen would be the iac valve not compensating for the power brakes,and i know if your booster check valve, or booster is not working properly it ill do the same</TD></TR></TABLE>
i thought mine was in the brakes, so i changed the booster and valve.
didnt work.
ultimately i think mine was a vacuum leak, but i cant say for sure. it is vacuum related tho. i can almost guarantee that
didnt work.
thanks guys keep em coming I will get some brake clean and check for vac leaks but again nothing came of those components came apart and were all cleaned less than 2k miles ago. keep it up with the suggestions
93egsir
12
Jul 8, 2007 06:52 PM
211811518
Sep 18, 2006 04:15 AM
