I have oil on top of my pistons...help???
Old Jun 24, 2007 | 07:22 PM
adam1027's Avatar
Default I have oil on top of my pistons...help???
I have a GSR motor fully built with a turbo, the motor was recently rebuilt with new pistons and rings. When the motor was fired, after breaking it in there was still oil on the pistons while sitting at idle, which is causing it to misfire under boost. Can anyone help???
Old Jun 24, 2007 | 07:35 PM
SpeedDreamz.com's Avatar
Default Re: I have oil on top of my pistons...help??? (adam1027)
is the motor smoking? Who built the motor? Tolerances? Were the valve stem seals replaced?
Old Jun 24, 2007 | 08:25 PM
adam1027's Avatar
Default Re: I have oil on top of my pistons...help??? (SpeedDreamz.com)
after you fire the motor it's smokin, all the seals in the head were replaced, it has new rings that were filed down to spec. There is no oil in the intake manifold either.
Old Jun 25, 2007 | 02:12 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Hey Adam, are the cylinders round? It almost sounds like the bores have ovalled to me
Old Jun 25, 2007 | 03:10 AM
Default Re: I have oil on top of my pistons...help??? (Clayton)
There are only a few ways oil can get into the cylinder. Getting past the rings, seals, or from the turbo thru the intake.
Old Jun 25, 2007 | 06:49 AM
g2turbo's Avatar
I have had similar occurences with my built motor. Pulling the plugs I can look down and see oil sitting on top of a few of my pistons from time to time... but the car still runs great, doesnt smoke, and oil consumption is very low. Also compression and leakdown numbers are good. Im sure its possible the oil is coming up through the oil control rings.
I replaced the valve seals on piston #1 and it seemed to clear up the problem for a while, but then it came back lol so it most likely wasnt the valve seals. Besides it seems like guite a bit of oil to get past the valve seals and still not be burnt up during combustion.
At this point I stopped worrying and just drive the car.
Old Jun 25, 2007 | 07:24 AM
BoostR41's Avatar
Default Re: I have oil on top of my pistons...help??? (g2turbo)
could it just look like oil because of the carbon on the tops on the pistons....are you sure it isn't over fueling and just leaving stuff wet when you shut it down.
Old Jun 25, 2007 | 07:27 AM
crazykid's Avatar
I belive these are fresh pistons he jsut put in his motor...
I wanna say thier CP Pistons.... g2turbo... what kinda pistons were you running?
Old Jun 25, 2007 | 09:03 AM
g2turbo's Avatar
Default Re: (crazykid)
CP pistons here as well.
Old Jun 25, 2007 | 09:05 AM
g2turbo's Avatar
Default Re: I have oil on top of my pistons...help??? (BoostR41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostR41 &raquo;</TD></TR><TR><TD CLASS="quote">could it just look like oil because of the carbon on the tops on the pistons....are you sure it isn't over fueling and just leaving stuff wet when you shut it down. </TD></TR></TABLE>
My oil is very fresh and still has the golden appearance. And the top of the pistons definitely appear to be oil and not fuel.
I thought it was fuel at first, and left the plugs out overnight and the fuel was still there in the AM... shouldn't it evaporate?
Old Jun 25, 2007 | 12:28 PM
HR-1320's Avatar
I had that happen on my hotrod car. The cylinders were getting out of round.
Old Jun 26, 2007 | 02:00 AM
Clayton's Avatar
H-T Administrator
25 Year Member
You make any progress yet Adam?
Old Jun 26, 2007 | 11:28 PM
eg:R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedDreamz.com &raquo;</TD></TR><TR><TD CLASS="quote">There are only a few ways oil can get into the cylinder. Getting past the rings, seals, or from the turbo thru the intake.</TD></TR></TABLE>
and spark plug seals on the valve cover
Old Jun 27, 2007 | 06:38 PM
adam1027's Avatar
Default Re: I have oil on top of my pistons...help??? (eg:R)
thanks for the help everyone. we've got the oil situation fixed, now the miss fire is still their. works great until we go over 23psi of boost then we get the miss fire back any idea's?
Old Jun 27, 2007 | 08:06 PM
msmotorsports's Avatar
So what was the cause of the oil getting into the cylinders?
Old Jun 28, 2007 | 04:33 AM
g2turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adam1027 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help everyone. we've got the oil situation fixed, now the miss fire is still their. works great until we go over 23psi of boost then we get the miss fire back any idea's?</TD></TR></TABLE>
Are you running stock ign? I am breaking up around 8-9k at 450 whp right now. It might be ignition im not sure yet.
Can the car running overly rich cause misfires?
How about lack of timing? Could this also cause misfires?
Old Jun 28, 2007 | 06:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg:R &raquo;</TD></TR><TR><TD CLASS="quote">
and spark plug seals on the valve cover </TD></TR></TABLE>
That will not get oil in the cylinder unless you pull the plugs out. That will only get oil in the plug holes.
Old Jun 29, 2007 | 06:31 PM
adam1027's Avatar
looks like we got the miss fire fixed and some good numbers at the dyno ,so we are off to the track tomorrow. thanks again everyone for the help
Old Jun 29, 2007 | 09:22 PM
adam1027's Avatar
not sure what the cause was, but we added the pcv valve back onto the car and let the motor run for a while thinking maybe it didn't hav eenogh time to seat
Old Jun 29, 2007 | 09:26 PM
adam1027's Avatar
as for the misfire problem we went to a bigger injector, and a new distributor and that seems to have fixed the problem there, and yes I'm still running a stock ignition for now
Rikaro
Nov 5, 2007 11:40 AM
slo_hatch
Oct 19, 2007 07:13 AM
EK FLY
Dec 4, 2005 02:27 PM
AzN_Flava
Apr 18, 2005 12:02 PM
BI8C1vic
Mar 11, 2003 09:15 PM
