sk2 68mm TB high idle can't bring it down.
Old Jun 24, 2007 | 06:11 PM
si90rex's Avatar
Default sk2 68mm TB high idle can't bring it down.
b16 68mm tb idles at 1200- 1500rpms i can't bring it down. the throttle cable is off and still nothin, i adjusted the idle screw still nothin, an the throttle stop is screw down too.
thanks for any help
Old Jun 24, 2007 | 06:21 PM
Wraith's Avatar
Default Re: sk2 68mm TB high idle can't bring it down. (si90rex)
are you sure you dont have a vacuum leak between the tb and manifold?
Old Jun 24, 2007 | 07:02 PM
Crx Jimmy's Avatar
Default Re: sk2 68mm TB high idle can't bring it down. (Wraith)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wraith &raquo;</TD></TR><TR><TD CLASS="quote">are you sure you dont have a vacuum leak between the tb and manifold?</TD></TR></TABLE> yeah I second that spray some carb cleaner around the TB gasket and see if the idle changes
Old Jun 24, 2007 | 07:03 PM
abnaasefmb's Avatar
X2 but if you still have trouble call SK2 help desk they will be happy to help
Old Jun 24, 2007 | 07:09 PM
Pee Wee's Avatar
Default Re: sk2 68mm TB high idle can't bring it down. (abnaasefmb)
I had a similar problem with mine. Not sure what ended up being the problem, but i eventually got it down to 900 .
Old Jun 24, 2007 | 07:12 PM
Crx Jimmy's Avatar
Default Re: sk2 68mm TB high idle can't bring it down. (Pee Wee)
did you adjust the idle screw in the new TB?
CRX_RR
15
Sep 21, 2008 05:14 PM
92ehatch
Apr 22, 2007 09:13 PM
1baddturbosi
Mar 19, 2007 04:06 PM
egCoupe
10
Aug 12, 2005 12:54 PM
gtowni3
16
Oct 9, 2004 10:53 AM
