Completely Resetting ECU
Old Jun 6, 2002 | 10:20 AM
gettz's Avatar
Default Completely Resetting ECU
Everyone keeps mentioning resetting their ECU...How exactly do you do that? Some say to disconnect the neg. terminal and pump the brakes others say that won't work. How do you do it? And is it the same for any Accord? And what are the benefits/negatives? Thx.
Old Jun 6, 2002 | 10:25 AM
SOHCArchangel's Avatar
Default Re: Completely Resetting ECU (gettz)
i dont think there are any benefits for OBD-II cars
Old Jun 6, 2002 | 10:26 AM
smokin rubber's Avatar
pull the neg battery terminal for about a minute,
Old Jun 6, 2002 | 10:51 AM
Kazmans94cord's Avatar
what would pumping the brakes have to do with resetting the ecu?
Old Jun 6, 2002 | 10:52 AM
Default Re: Completely Resetting ECU (kazmans94cord)
yeah, who said that origionally?
Brandon's Avatar
Life is Suffering
It discharges the capacitors in the electrical system which may have residual charge.
Old Jun 6, 2002 | 11:35 AM
Default Re: Completely Resetting ECU (vtec2k2)
another load of scc chit
Old Jun 6, 2002 | 12:04 PM
Brandon's Avatar
Life is Suffering
Default Re: Completely Resetting ECU (smokin rubber)
Don't be messin with Sport Compact Car now. They know their ****, if you read correctly, it did reset the ECU.
Old Jun 6, 2002 | 03:19 PM
KTeller8's Avatar
i cut the car off and pull the battery. it seems to F**K up my radio so.. id say why not the ECU
Old Jun 6, 2002 | 05:13 PM
Gennady's Avatar
New User
Default Re: Completely Resetting ECU (KTeller8)
Disconnect negativer terminal, pull ECU fuse, pull hazard light fuse, let sit for 10 minutes. Replace everything and let idle for 10 minutes.
Old May 18, 2011 | 11:16 AM
kernl's Avatar
2002 acura tl-s: ok, so what to do when this reset WONT work? im having a MAJOR issue here.. the vsa,cel,abs,d5 lights are all flashing crazy. i tried to reset the ecu, removing the battery cable, removing fuses, even a snap-on heritage scanner WONT ease the problem! wtf?!?!? im getting a BOAT LOAD of codes being thrown my way,.. (dtc list) p1298, p0135, p0141,and p1768. aswell as, over 100 -abs- codes. i know what the dtc codes are, that is simple. erasing them and/or fixing them seems the issue.
how it got this way, you ask? -not many ideas.. i changed the axles,replaced struts, replaced the timing belt,water pump, motor mounts, added headers and intake, replaced the cat, and the rest of the exhaust system, using the same stock mufflers.
i dont understand how doing these SIMPLE and COMMON tasks have led to this massive mess. i can understand frying the o2 sensor, or something like that, but getting failing transmission codes?? - i dont get it!
-admitting defeat (so far) HELP!!
Ek4drcindy
Mar 18, 2011 03:55 PM
1990hondaHF
Jul 27, 2009 08:12 AM
MilanoCpe
Feb 7, 2007 02:30 PM
91civichatchCrX
Feb 11, 2006 11:11 PM
dvcart106
Aug 9, 2003 12:42 PM
