cut turn signals
the past owner of my 95 integra cut the turn signal lights in the front of the car. the wire is there but there is no bulb or clip. all that is left is a cut wire that goes to the clip/bulb. i ordered the turn signal casing but i need the other wire to the clip/ bulb. i know im going to have combine the cut wire and clip/bulb. does any one know where to find the clip/ bulb. i probably will not be able to fix but i thought i would ask. the junk yard would be the best place to find it but i dont think we have one in this town. if some one knew a site that i could go to that would be great. thanks in advance.
i think you can look in your yellow pages for the nearest junk yard. and that would propably be the best place to get what you need. it'd help if you had a pic so we know exactly what it is your missing, cause im a little confused, i belive you mean the bulb and the plug you put the bulb in. but im not exactly sure...
why would the previous owner screw up the turn signals?
the wire that goes from the car to the turn signal light bulb has been cut. there is no light bulb or case. i tryed to put a picture on but i dont know how on this site. all i can do is describe it to you. there is just an empty spot. im sorry that i cant do more. thank you for your help.
well again, id say just look in the yellow pages for a nearby junkyard and go get everything from where it was cut by the previous owner.. easiest and cheapest way.
kasperxtcy
22
Sep 23, 2010 09:23 PM
