Car pops out of 4th
I have a 90 integra w/ a ys1 tranny...When i just drive around whenever i shift into 4th it pops out as soon as i hit the gas...But if i shift then let the clutch out what a sec then hit the gas it will stay in...Also if i'm going aroud a corner to the right it will pop out....What is going on the tranny only has 70k on it?
i had the same problem in my b20 with gsr tranny it kept poping out of 5 gear,
i put tranny oil in and it was fine after that.
check maybe you need some oil.
the syncros start over heating and it pops out of place
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitepandaeg6 »</TD></TR><TR><TD CLASS="quote">i had the same problem in my b20 with gsr tranny it kept poping out of 5 gear,
i put tranny oil in and it was fine after that. </TD></TR></TABLE>
x2
Low trans fluid will Definitely make it pop out of gear,
and if you don't fill it soon enough, I'm sure everyone knows what happens next.
x2
