turbo timer
a turbo timer allows your car to keep running after you take the car keys out. it counts down. when the set time is up, the car will turn off by itself. a turbo timer prolongs the life of a turbo setup because immediately turning off a car is bad for it
btw, you didn't search. if you google, the first result for turbo timer is wikipedias:
http://en.wikipedia.org/wiki/Turbo_timer
read wikipedia damn it!
With regard to modern automotive turbochargers, the need for a turbo timer can be eliminated by simply ensuring the car does not produce any 'boost' (during driving) for several minutes prior to the ignition being shut off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunerkid7 »</TD></TR><TR><TD CLASS="quote">so it is basically essential?</TD></TR></TABLE>
no, just requires you to sit with your car idling for 30seconds
Snafu-Si
May 9, 2002 01:01 PM
