Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Brake rotor install question
Old Jun 23, 2007 | 01:44 PM
pyork03's Avatar
Default Brake rotor install question
Hey guys, my front passenger rotor is bad and I need a new one. Just seeing if anybody here has changed their rotors and if there is anything I need to watch out for or any tips you could offer. Also about how long did it take you to install them? Im going to be doing the rotors and pads at the same time.
These are going on a 02 civic ex coupe
Thanks
Paul
Old Jun 23, 2007 | 01:58 PM
DankasCivic's Avatar
Default Re: Brake rotor install question (pyork03)
It should only be like 2 screws kinda between the studs thier only 1/4 inch long that you remove. if you have changed pads before, the rotors should be not much harder to replace i have not done my own brakes in like 2 years though i'm getting lazy in my old age of 24 but i'm prety sure thats all that need to remove them
Old Jun 23, 2007 | 02:08 PM
toyomatt84's Avatar
Sanji
They're quite easy to do, to be honest. I got mine done in about 30-45 minutes, and I was taking my time.
Old Jun 23, 2007 | 02:54 PM
pyork03's Avatar
Default Re: (toyomatt84)
Sweet, yeah I have changed the pads and brake lines on a WRX and it wasnt bad at all, just making sure there wasnt something odd or anything.
I took it to honda today and they told me it would be like 400 and something to put new rotors and pads on. I told them to shove it up their *** and I left.
Old Jun 23, 2007 | 10:05 PM
awang's Avatar
Default Re: (pyork03)
if you know how to do it, why'd you bother even going to honda?
Old Jun 24, 2007 | 05:43 PM
pyork03's Avatar
Default Re: (awang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awang &raquo;</TD></TR><TR><TD CLASS="quote">if you know how to do it, why'd you bother even going to honda?</TD></TR></TABLE>
I live in an apartment complex and dont have a lot of space or garage or anything to do it in. I also work full time and go to school full time so dont have a whole lot of free time.
Old Jun 24, 2007 | 05:58 PM
Boilermaker1's Avatar
drill the rotor screws out, you dont need em.
have a 4" or larger C clamp handy to push the piston back in.
Its easy. I did pads and rotors friday in less than half an hour.
Old Jun 25, 2007 | 04:55 AM
anonnonator's Avatar
Default Re: (Boilermaker1)
yea, it's not that hard, just remember to put some brake slider grease on when putting new pads on. That'll keep em from seizing up in return saving your rotors from damage.
Old Jun 25, 2007 | 05:27 PM
IN VTEC's Avatar
There's an alternative to drilling out the rotor retaining screws. One of the dealership techs showed me how to use a small chisel and a hammer to knock the screw loose after I had broken off an impact driver bit into the head of the screw and tried to drill it out.
He knocked it loose in one tap. Saved me an hour of trying to drill through the impact driver bit.
Old Jun 25, 2007 | 05:29 PM
WhiteOnRice's Avatar
Is that the whole technique?
eastbayrep
15
Oct 14, 2006 03:26 PM
DB1_559
Oct 1, 2006 08:27 PM
-16V-
Mar 13, 2004 10:01 PM
ryanhook
May 6, 2003 03:44 PM
xcivicdx
Apr 4, 2003 06:30 PM
