Which is Shorter? sir1 or teg int. shaft
trying to finish up an ls swap into my 85 civic hatch and ran intoa bit of trouble with the drivers side axle, as it appears to be around 1" too long. axle is an 86-89 integra unit. so my question is.
what is the shortest b series axle, and what is the shortest b series int. shaft?
after searching im under the impression the shortest b axle is the 86-89 integra and the shorest int. shaft is the sir1
im changing my ball joint out for an 86-89 and it should give me 1/4 inch, but i fear its not enough,
Look at the bracket on the intermediate shaft, there is a casting code stamped into it. If the casting code is SH3, it is 1" longer than the Integra style (SK7).
thanks alot! casting code is sk7, i can no finish my swap without a custom axle shaft (but what would it of mattered, since it custom moutns and linkage)
B16CRXT
Jun 23, 2006 02:05 PM
B16CRXT
Jun 23, 2006 11:09 AM
Burlyirishdude
Apr 23, 2006 10:28 AM
