Rod modification
Old Jun 22, 2007 | 02:06 PM
paulITR's Avatar
Default Rod modification
I have got a set of type r rod modified to install Wiseco pistons.
They get discoloreted for the heat used to make the work:
http://www.imagestation.com/my...4.jpg
Could the rods be weak from it and going to fail?
Old Jun 22, 2007 | 06:57 PM
Lubo_25's Avatar
Default Re: Rod modification (paulITR)
hmm...dont know how healthy that looks...use at own risk
Old Jun 22, 2007 | 07:17 PM
coneheadsracing's Avatar
Default Re: Rod modification (Lubo_25)
From what i've read that means you, or whomever got it hotter then it needed to be. HOwever, my friend ran rods like that in his b16 with 10 pounds of boost. I too said the same thing, when it breaks we'll know why However, no issues, i have since done my own rods, and ended up with the same color. So, from my limited experience, i say your good to go.
Old Jun 22, 2007 | 11:25 PM
paulITR's Avatar
Default Re: Rod modification (coneheadsracing)
The rods will go in a 210-215whp 9500 rpm NA application.
Is there any real risk?
Old Jun 22, 2007 | 11:27 PM
Chris Tune's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulITR &raquo;</TD></TR><TR><TD CLASS="quote">I have got a set of type r rod modified to install Wiseco pistons.
Could the rods be weak from it and going to fail?</TD></TR></TABLE>
what hence modification it needs? wiseco pistons can be pressed pin... like stock
they installed a bronze bushing like a forged rod... i have had some done... and some that doesn't... but the ones done dont look like that at all...
civic_saints1
Jul 7, 2007 05:23 PM
K2e2vin
Jun 12, 2006 01:10 PM
johncarlos
May 1, 2004 02:51 AM
