Final Question with B16 ARP head studs need to ORDER ASAP
Old Jun 6, 2002 | 02:33 AM
BLKCRX's Avatar
Default Final Question with B16 ARP head studs need to ORDER ASAP
Hey all need a little advice.. just before I order my ARP head studs.
I talked to ARP and they said they have two products for b16’s
Short ( for the b16a)
part number 208 4601
$137.22
Length 7.100 " 11
long (for the b16a2)
Part number 208 43 03
$151.51
Length 7.25" 11
My problem is that im using a b16a block and everything else is off a b16a2 ( including the head) apart from je pistons/rings and eagle rods.
Does anyone know if the difference in the bolts is in the head thus I order the b16a2 bolts, or if the difference is in the blocks, so I should order the b16a kit )
I talked to Honda Australia, and they seemed to think there was no block difference, and the only difference was in the head, I plan to call ARP tomorrow again and ask if the studs are different in length at the block end or at the head end..but also wanted you guys thoughts on this matter.
ARP also wanted me to measure my block and head.. thus calculate what I need, but my block is begin sleeved in one work shop, and my head’s in another… and I want these studs shipped by Friday because my brother already has a shipping of stuff coming out to Australia.. lol if only there was more time.. Actually if only you could fast forward and reverse time.
Thanks heeps guys any comments to help rest my mind would be great.
Regards James
Old Jun 6, 2002 | 06:04 AM
turbo Si's Avatar
Default Re: Final Question with B16 ARP head studs need to ORDER ASAP (BLKCRX)
WOAH.....i think your making things a little too difficult for yourself. I have a B16A2 and I had to use B18C ARP head studs because thats all they had available back then. I guess they started making some for B16's although I am almost positive there is no difference between any B16 block and the studs should be the same for every B16. Those prices are also kind of steep. Call around, you should get them for about 100.00 bucks.
Good Luck!
Old Jun 6, 2002 | 06:16 AM
BoOsTeD_eK's Avatar
Default Re: Final Question with B16 ARP head studs need to ORDER ASAP (turbo Si)
Use the ones that coresspond to the head that you are using.
big_joe1
Aug 3, 2009 12:56 PM
95civiccpdx
Oct 22, 2007 02:34 PM
markvqwerty
Oct 19, 2004 08:12 AM
Brian_92GSR
Oct 6, 2002 08:21 PM
