will 92-95 civic d16 mounts fit in an 96 with a y8???
OK so basically I have a set of Innovative engine mounts that i picked up off of ebay for cheap and I was wondering if they will fit....
right now the car is a 96 civic hb with the original engine in it (d16y7) and I'm currently building a d16y8 for boost. So in about a week and a half I'm going to be swapping the y8 into the EK and i was wondering if the engine mounts that i have (innovative engine mounts for a 92-95 civic) will fit and if everything will bolt up?
Now i know that the 92-95 civics use the d16z6 engine and I'm pretty sure that the mounts connecting to the block will be fine because the z6 block itself is the same as the y8 one....can somebody confirm this for me?
But even if the block mounts bolt up fine, I've still got one other mount for the head that has to connect....will this mount fit?
thanks alot for your responses
Patrick
Patrick
No.
If I recall correctly they're all the same except for the driver-side mount which is different between 5th generation and 6th generation civics.
EDIT:
Might wanna get some clarification on that though.
EDIT:
patrickd_21
May 29, 2007 09:07 AM
