Turbo manifold question.
Old Jun 21, 2007 | 10:58 PM
danielm3's Avatar
Default Turbo manifold question.
I am going to be building a turbo manifold for a 2jzge soon and I am kind of stuck as to what material to use. I have been reading on here that Sch 10 and 40 is the way to go, but I also read 16g should work. Since I have my own bender ideally I would love to make something out of 16 guage, but I am not sure how reliable it would be. I read on here that if you brace it will be ok, what would be a proper way to brace it?
Old Jun 22, 2007 | 03:02 AM
DaveF's Avatar
Default Re: Turbo manifold question. (danielm3)
build a brace that would support the full weight of the turbo ( it would hold the turbo in position, if you were to remove the manifold) ive seen some real nice looking triangulated, heim joint type braces in use. on our racecars(we use thick *** pipe) we have a single tube heim joint type brace, which supports the turbo from the bottom
Old Jun 22, 2007 | 06:31 AM
tony1's Avatar
Default Re: Turbo manifold question. (dturbocivic)
Yeah, the ideal brace is one that allows the turbo to hang from a heim joint. This way the manifold is not supporting the weight of the turbo, but it is free to expand and contract easily since the turbo can "swing" on the heim joints.
Old Jun 22, 2007 | 08:28 AM
danielm3's Avatar
Default Re: Turbo manifold question. (tony1)
Thanks guys. If you guys maybe have some pictures, that would help even more.
Old Jun 22, 2007 | 08:43 AM
danielm3's Avatar
Found some pictures for anyone who is in need of this also:
Old Jun 22, 2007 | 01:01 PM
tony1's Avatar
Old Jun 22, 2007 | 03:10 PM
MrParks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danielm3 &raquo;</TD></TR><TR><TD CLASS="quote">Found some pictures for anyone who is in need of this also:
how did you get this pic? this is my friend chippys car at twinsturbo.
Old Jun 22, 2007 | 05:16 PM
danielm3's Avatar
Default Re: Turbo manifold question. (MrParks)
I got it from a google search and than hosted it on my server.
Thanks Tony!
Old Jun 22, 2007 | 05:21 PM
danielm3's Avatar
Also, where is a good place to get the joints?
Old Jun 22, 2007 | 05:29 PM
*Boostwerks*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danielm3 &raquo;</TD></TR><TR><TD CLASS="quote">Also, where is a good place to get the joints?</TD></TR></TABLE>
Mcmaster carr.
Heres a heim setup I recently finished:
Old Jun 22, 2007 | 06:01 PM
sharkytm's Avatar
http://www.qa1.net/
Carrera/QA1 has a huge selection, and are good people.
Old Jun 24, 2007 | 07:28 AM
.RTErnie's Avatar
Default Re: (sharkytm)
I have hundreds of heim joints...hit me up. Brand new in packaging. I got them from West race cars.
http://www.westracecars.com/in...t=757
WRC-10-041 3/8 RH Rod End
I have a tooooon of these I need to get rid of. I paid 15 dollars for them too :-P
LMK how many you need and I'll hook it up.
Old Jun 24, 2007 | 03:47 PM
t3t41.8tgti's Avatar
Default Re: (.R T E r n i e)
what would happen if you built a brace on the bottom of the turbo to motor. Something like factory turbocharged cars have.
Old Jun 25, 2007 | 02:02 AM
hondaapi's Avatar
Default Re: (t3t41.8tgti)
I do it this way and never had a problem the past two years.
Hope I´ll not get problems on that case.
Old Aug 14, 2007 | 09:59 PM
danielm3's Avatar
Default Re: (hondaapi)
This is what I ended up making:
and this is the manifold I ended up making:
Old Aug 15, 2007 | 11:32 AM
hootiehoo's Avatar
i know a brace is super easy to make from scrap, but some people like to just buy it and have it look nice....
http://www.034motorsport.com/p...d=704
Old Aug 16, 2007 | 08:02 PM
HiProfile's Avatar
Default Re: (danielm3)
I'm guessing you used 16ga? Its what the 'baller' manifolds are on some Evo's, its just more touchy when it comes to weld quality and bracing. Since you have 50% more runners than a Honda, it also gives it that much mroe ability to carry weight.
I have to say it looks like a well-done job. Every time I look at my friend's IS300, I wondered if one could keep the OEM TB location and fit a turbo in - I always figured it'd be easier to make your own plenum for the runners like they do on lots of SC300's That must be a wonderful DD car, long-runner IM with a non-oversized turbo on a big I6. *drool*
Old Aug 16, 2007 | 10:12 PM
danielm3's Avatar
Default Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">I'm guessing you used 16ga? Its what the 'baller' manifolds are on some Evo's, its just more touchy when it comes to weld quality and bracing. Since you have 50% more runners than a Honda, it also gives it that much mroe ability to carry weight.
I have to say it looks like a well-done job. Every time I look at my friend's IS300, I wondered if one could keep the OEM TB location and fit a turbo in - I always figured it'd be easier to make your own plenum for the runners like they do on lots of SC300's That must be a wonderful DD car, long-runner IM with a non-oversized turbo on a big I6. *drool*</TD></TR></TABLE>
Thank you. Yeah it's 16g and yeah having 2 more tubes helps with the weight.
Now that I have the turbo on, I don't think I can live without it. I get full 7psi at 3500 RPMs so when I need the power it's right there, when I don't the car feels 100% stock and is very quiet.
I want to test it out for the next few weeks see what, if anything, will go wrong and if all looks good I am going to start selling these kits.
Old Aug 17, 2007 | 06:26 AM
hoya_10fintec's Avatar
Sorry, not to steal anybody's thread but..
I've been curious for a while since I've decided to start making turbo manifolds for myself and others.
how the hell do you weld around where the pipes meet the collector? I can weld two pipes maybe 3 but I can't figure out how I can weld the rest.
I mean this.. How do you reach to weld around the ends of the pipes that meet the collector??:
/O O
\O O &lt;--- collector
Modified by hoya_10fintec at 6:23 PM 8/17/2007
Old Aug 17, 2007 | 05:41 PM
danielm3's Avatar
Default Re: Turbo manifold question. (hoya_10fintec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoya_10fintec &raquo;</TD></TR><TR><TD CLASS="quote">Sorry, not to steal anybody's thread but..
/O O
Modified by hoya_10fintec at 6:23 PM 8/17/2007</TD></TR></TABLE>
When I made my manifold, I made sure I would have enough room to weld the last tube. I did this by designing the collector just right (angle and spacing). The last one is always the hardest.
Old Aug 18, 2007 | 12:05 PM
any pics of the precedure would be appreciated! anybody!
Old Aug 19, 2007 | 11:43 PM
93LSivic's Avatar
Looks real good man! You need our GE intake plenum on that thing
S375CRX
Welding / Fabrication
14
Mar 4, 2016 08:01 PM
BoostdK
Oct 24, 2009 07:57 AM
wade
Jul 1, 2007 11:16 AM
all_motor_mike
Jun 5, 2006 01:06 AM
typeRmini
Jan 21, 2005 09:59 AM
