lights dim after swap??
I have a 99 civic lx with a 96 jdm gsr motor. After the swap my headlights and interior lights dim depending on rpm and if I push down on the throttle. Above 4k the lights go to normal brightness. Below 4k it only dims if I'm on the throttle or at idle. I changed the alternator and it still does it. The old alternator was good too. I've checked all my grounds and the wiring and now I'm stumped. I read about the service bulliten. Also i don't have an o2 sensor after the cat would that be a problem... cause there isnt a check engine light. thanks.
EDIT:::: i read about cutting the altc wire to the ecu would fix that.... is this true, any negitive effect to this?
