How do you wire the high beams to stay on by themselves?
Old Jun 5, 2002 | 11:46 PM
bustaman0763's Avatar
Default How do you wire the high beams to stay on by themselves?
Does anyone have their high beams wired to stay on by themselves, or have city lights inside of the high beam housings? If anyone has pictures of this done on their car or info on how to go about doing it i would greatly appriciate it
Old Jun 6, 2002 | 12:44 AM
PaChiLa Leader's Avatar
Default Re: How do you wire the high beams to stay on by themselves? (bustaman0763)
All canadian model cars are like that....
go up to Canada and get a CDN model
saving hassles......
i have learned my lesson of not messing around my wires....
my advise to you will be ... leave it alone
[Modified by PaChiLa Leader, 1:44 AM 6/6/2002]
Old Jun 6, 2002 | 04:49 AM
TGUNNER's Avatar
Default Re: How do you wire the high beams to stay on by themselves? (PaChiLa Leader)
dissconnect your headlight bulbs.. and just drive wit the high beams on!!! its that simple, but its illegal... good luck!!!
Old Jun 6, 2002 | 07:58 AM
quikB18B's Avatar
Default Re: How do you wire the high beams to stay on by themselves? (TGUNNER)
Why you want both lights on? you going to rally race the car or what. Just leave it alone like what was said dont mess with stuff like that.
Old Jun 6, 2002 | 08:18 AM
PM-Performance's Avatar
Default Re: How do you wire the high beams to stay on by themselves? (quikb20)
i kinda want the same thing . i saw it somewhere and it was hott. i just want the high beams on , and when the high beams switched on have them both on .
Old Jun 6, 2002 | 08:25 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: How do you wire the high beams to stay on by themselves? (itr206)
That's weird, my Integra and all my friend's Integras can have both sets of lights on.
Unless we're talking about something different here.
Old Jun 6, 2002 | 08:29 AM
Default Re: How do you wire the high beams to stay on by themselves? (shamoo)
i want to make my light vice versa. . . the highs be the lows and the lows be the highs.
see what im saying. i want the inner lights to be the low beams and them both on as usual when the high beams are switched on .
Old Jun 6, 2002 | 08:50 AM
dbman96's Avatar
New User
So swap the plugs between the low beam and high beam bulbs. Should take you about 60 seconds, maybe 5 minutes if you're really not mechanically inclined. You will need to trim the little ridge of plastic off the bulb's connector so the plug will slide on. Look at the plug on a 9005 and a 9006 bulb side by side and you'll see what I'm talking about. Xacto knife or dremel makes very short work of it.
Now you too can look like you're driving a Saturn.
Old Jun 6, 2002 | 09:03 AM
Default Re: How do you wire the high beams to stay on by themselves? (dbman96)
cool , i always wanted a saturn .
acura is over rated
Old Jun 6, 2002 | 09:13 AM
Fooser's Avatar
You would have to find the relay the powers both beams, then cut the wire that powers your regular lights. its probably by your switch on the steering wheel. Look in your helms manual I'm sure it will have a wireing diagram in there somewhere. My opinion is dont mess with that. It will become a big trouble.
[Modified by Fooser, 6:38 PM 6/6/2002]
Old Jun 6, 2002 | 09:29 AM
Cramerox's Avatar
you cant do anything with usdm cars. Cnd cars have them on in the center as daytime running lights. If you swap the plugs, the highbeam housing doesnt have a lense so you will always look like you have high beams on. Basically leave it alone its not even worth it. I took my whole bumper of just to try to figure this out. If you really wanted to do it-maybe you can ask someone in canada to see who their cars have it riged up.
You can definitly rig something up for some low wattage bulb to go in the high beams, so you have all for lights on....its not worth it in my book.
[Modified by Cramerox, 10:31 AM 6/6/2002]
Old Jun 6, 2002 | 09:45 AM
Jesse H's Avatar
This thread is gay
Old Jun 6, 2002 | 10:10 AM
As i Said......
it only came stock with Canadian Model vechicles
it's because of the road condition purpose.... ppl up north has fogs and ****.
And yes, my 01 teg just like you describled..... have high beams on... but that's not the actual high beam...... the voltage is lower ......
anyways, this is gay
Old Jun 6, 2002 | 11:15 AM
neo1z's Avatar
im running that right now -- people hate you.
Old Jun 6, 2002 | 11:16 AM
neo1z's Avatar
Default Re: How do you wire the high beams to stay on by themselves? (neo1z)
oh but im not doing it on purpose, i had a harness burn on my passenger side low beam, so it doesnt work and i am NOT going one headlight...hell no
Haysie149
Honda Civic (2001 - 2005)
Aug 27, 2018 02:55 AM
SiRkid
Mar 16, 2007 11:42 AM
vtec4lyfe
Feb 14, 2007 04:56 PM
4DRmafia
12
Jun 11, 2004 01:50 PM
