I need advice with dent
Old Jun 21, 2007 | 08:21 PM
ryanjoe's Avatar
Default easy fix?
Car was rear ended. The taillights were replaced already. Would the quarter panel be an easy fix? Ive never done body work but down to try. Would this be something a noob would be aable to pop out and bondo? Would I be able to get the dent removed and painted for under $200?
Modified by ryanjoe at 2:06 PM 6/22/2007
Old Jun 22, 2007 | 04:02 AM
WihaSi's Avatar
Default Re: I need advice with dent (ryanjoe)
Depends on how bad the dent is. You said you were rear ended, is the quarter panel buckled? If it's buckled you may need to get it on a frame machine and pull it. You may have frame rail and rear body panel damage. If it's just a regular dent, of course you could fix it yourself. Just read up on body repair, and make sure you have the right tools for the job.
Old Jun 22, 2007 | 08:40 AM
lil vin's Avatar
Default Re: I need advice with dent (WihaSi)
u can try dry ice
GYChris
Paint and Body
Sep 3, 2007 03:04 AM
-[95cxhatch]-
14
Feb 14, 2006 08:31 AM
NXLude
Oct 11, 2005 05:21 PM
mafioso102
Feb 10, 2004 08:24 PM
blackfrohatch
Feb 2, 2003 05:11 PM
