ecu codes, try to read but engine light just stays on
Old Jun 21, 2007 | 06:49 PM
jdmland's Avatar
Default ecu codes, try to read but engine light just stays on
Alright found out that the ecu staying on when i put the clip in means i have no codes, but my car still has no spark, can i use a ls obd0 distributor for now? its a 94 jdm gsr obd1 conversion with hondata s200 chipped, reason i'm asking is because i don't know if using the ls distributor will effect the hondata? i'm not going to beat on it just need to get it to the garage.
Modified by jdmland at 6:46 PM 6/22/2007
Old Jun 22, 2007 | 06:18 AM
jdmland's Avatar
Default Re: ecu codes, try to read but engine light just stays on (jdmland)
morning bump
Modified by jdmland at 6:43 PM 6/22/2007
Old Jun 22, 2007 | 05:47 PM
jdmland's Avatar
Help??
Old Jun 22, 2007 | 07:03 PM
mtber's Avatar
You need to run an obd1 distributor with an obd1 ecu
Old Jun 22, 2007 | 07:04 PM
myfirstdc2's Avatar
also if u don't have a check engine lite on then u won't be able to pull codes cuz there isn't any stored. shorting that plug won't help if u don't have codes
Derrick_12341
10
May 21, 2018 07:41 PM
lgoodgrace
Apr 27, 2015 03:35 PM
Kid-jdm-teggy
Apr 26, 2014 02:27 AM
chriscool888
Jan 3, 2012 01:27 AM
SETxTHExSTAGExEJ1
Dec 1, 2007 05:12 AM
