What the easiest way to Install a new Tranny?
Old Jun 21, 2007 | 05:25 PM
sirhavok's Avatar
Default What the easiest way to Install a new Tranny?
So i got my little hands on a good b16 tranny..
i wan tot drop it in my 89' civic hatchback si
my old one was completely dead. no 3rd OR 4th gear.
so what are some DO's and DONT's when install a new tranny?
All i can think of, is to just label everything so i can put it back together easily.
do i need to take the whole motor out? or just lift one side.?
-Brandon
Old Jun 21, 2007 | 05:38 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: What the easiest way to Install a new Tranny? (sirhavok)
Just keep in mind that 3 of the 4 engine mouts are on the tranny.
You can do it yourself but if it's your first time, get a friend to help you and definitely use a jack to support the engine
Before you jack the car, remove the two axle nuts, those can be hard to remove.
It's not hard, but there are a lot of steps.
Old Jun 21, 2007 | 05:40 PM
sirhavok's Avatar
well actaully, i had a 2004 sentra 1.8s that i swapped in a sr20de into. So i have somewhat of an idea of what im doing.
i know how take the motor out,
im just trying to see if there is an easy way with a honda. I really dont wanna have to take of the complete engine harness and pull the motor completely out.
thx for the help.
XD
Old Jun 21, 2007 | 05:57 PM
Sikocivic's Avatar
Default Re: (sirhavok)
I have found that pulling the motor and tranny in one unit and the swapping the trannys is the easiest way to go on these cars. I have done it by blocking up the motor and pulling just the tranny but it was a BIG pain and took longer. I can pull the motor and tranny in about 1 HR.
Old Jun 21, 2007 | 06:00 PM
90 Si Hatch's Avatar
Default Re: (Sikocivic)
after doing it some many times..... me personaly i would remove the whole motor and transmision!
Old Jun 21, 2007 | 06:01 PM
.Manny.'s Avatar
Touching My Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic &raquo;</TD></TR><TR><TD CLASS="quote">I have found that pulling the motor and tranny in one unit and the swapping the trannys is the easiest way to go on these cars. I have done it by blocking up the motor and pulling just the tranny but it was a BIG pain and took longer. I can pull the motor and tranny in about 1 HR. </TD></TR></TABLE>
neh, swapping the tranny is cake. look around for a guide.
ridestrt
17
Aug 29, 2003 11:17 AM
Shaun
Apr 8, 2003 07:49 PM
TypeR0207
Mar 24, 2003 02:47 PM
Inaniac
28
Oct 20, 2002 11:36 AM
SUis1
Oct 22, 2001 09:03 AM
