Help! GSR Swap
Old Jun 21, 2007 | 04:40 PM
jmiddle1's Avatar
Default Help! GSR Swap
I am doing a 94-95 GSR with LSD swap into my 2000 Civic. There are questions on whether the cv axles and spindles will need to be changed. Can anyone please help me. I plan on getting this swap done within the next 2-3 weeks. I also would like to know what all do I need for the swap to be done. So far I have a P72 ECU, 99-00 SI Driver side motor mount and bracket, wiring harness, and distributor. Is there anything else I am missing?
Thanks in advance!
Modified by jmiddle1 at 7:23 PM 6/21/2007
Old Jun 21, 2007 | 06:26 PM
jmiddle1's Avatar
Default Re: Help! GSR Swap (jmiddle1)
bump
Old Jun 21, 2007 | 08:11 PM
slowcivic2k's Avatar
There is plenty of info in the swap posts, try the search function next time, your not the first person to do this.
You will need a 99-00 si rear engine mount, and thats it. You will need the alternator plugs from an obd1 honda, and an obd1 distributor (which it should already have), also, a obd1 jumper harness. Your swap otherwise if your vtec will be straight forward. Drop it in, axles are the same spline. Your swap will eliminate the purge solenoid on the fuel rail, the crankshaft fluctuation sensor, the purge valve on the canister under the battery, and the second O2 sensor if you do it this way (which I highly suggest) Use the 2000 harness and rape the gsr one for clips, you will need the rewire the distributor and the alternator plugs.
Old Jun 21, 2007 | 09:13 PM
LastGenEK's Avatar
hey bro im in the same boat as you i have a 2000 ek coup with a obd1 gsr w/p72
kennybintegra
13
Nov 24, 2019 09:22 PM
CiviCVuE
Mar 9, 2007 03:33 AM
scivicex99
Jun 20, 2004 08:25 PM
