widest tire???
Old Jun 21, 2007 | 12:35 PM
otto's Avatar
Default widest tire???
I have an 89 Honda CRX and would like to fit wider tires. I have seen tires as big as 205-50-15. I would like to go with a 15 inch wheel but would like to go wider that 205. What could I do to fit bigger tires without going to extreme. Thanks Honda-tech!!!
Old Jun 21, 2007 | 04:14 PM
Crx Jimmy's Avatar
Default Re: widest tire??? (otto)
I had 225/45/15 with no problems, well I had them squeezed on to 6" wide ls mesh wheels, So they were made slightly narrower. Most tire shops would not even attempt this though.
Old Jun 21, 2007 | 06:01 PM
Pee Wee's Avatar
Default Re: widest tire??? (Crx Jimmy)
I ran 225-50-15s with only a slight rub at full lock
Old Jun 21, 2007 | 06:13 PM
fireant's Avatar
Default Re: widest tire??? (Pee Wee)
205 Azenis are as wide as most 225s... and cheap too.
Old Jun 21, 2007 | 06:19 PM
abnaasefmb's Avatar
Default Re: widest tire??? (fireant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">205 Azenis are as wide as most 225s... and cheap too. </TD></TR></TABLE>
not too sure about that maybe 215.
what are you trying to hold hp wise? you could try a better compound i have the bfg's and they grab better that the old azenis i had of the same size.
Old Jun 21, 2007 | 09:07 PM
KevinT707's Avatar
Must be because of the stock wheel offset then, cause 225 on my 17x7 rubbed like crazy!
Old Jun 21, 2007 | 09:22 PM
RockinthEFhatch's Avatar
Default Re: widest tire??? (KevinT707)
No EF should have 17" wheels anyways...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">
what are you trying to hold hp wise? you could try a better compound i have the bfg's and they grab better that the old azenis i had of the same size.</TD></TR></TABLE>
x2
I run 205-50-15 KDW's and they grip like crazy (BFGoodrich)
Old Jun 22, 2007 | 02:25 AM
abnaasefmb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KevinT707 &raquo;</TD></TR><TR><TD CLASS="quote">Must be because of the stock wheel offset then, cause 225 on my 17x7 rubbed like crazy!</TD></TR></TABLE>
Old Jun 22, 2007 | 06:09 AM
otto's Avatar
Current HP @ the wheels is 275. I would like to turn the boost up a little more. I want to stay with a 15 inch wheel. The more tire contact I can put down the better. Also, what offset wheel should I be looking at. Thanks again Honda-tech!!!
Old Jun 22, 2007 | 06:38 AM
abnaasefmb's Avatar
Let me guess, if you hold full throttle you spin first and after the shift to second if your in vtec your wheels come loose too?? You need bfg drag radials with those numbers. It’s all about the compound.
Old Jun 22, 2007 | 08:26 AM
fireant's Avatar
Default Re: widest tire??? (abnaasefmb)
Even the new 615s are way understated in size:
205/50/15 Azenis 215s (left) | 225/45/15 Hankook RS-2 Z212 (right)
My point is tire widths arent consistent from brand to brand... the new Bridgestone RE-01Rs in 195/50/15 (available later this summer) are also around the size of 225s.
Modified by fireant at 3:34 PM 6/22/2007
Modified by fireant at 3:35 PM 6/22/2007
Old Jun 22, 2007 | 09:37 AM
otto's Avatar
Wow! Very interesting!! What offset should the wheel be? Also, should I be looking at a 6.5 or 7 or 7.5 inch wheel?
Old Jun 22, 2007 | 09:44 AM
abnaasefmb's Avatar
205/50/15 Azenis 615s (left) | 225/45/15 Hankook RS-2 Z212 (right)
My point is tire widths arent consistent from brand to brand... the new Bridgestone RE-01Rs in 195/50/15 (available later this summer) are also around the size of 225s.</TD></TR></TABLE>
funny i tryed the bfg's in 225 and it wasn't going to happen. they were much bigger and wider than the falkens.
Old Jun 22, 2007 | 09:45 AM
abnaasefmb's Avatar
7' 40mm
Old Jun 22, 2007 | 09:47 AM
drummingpariah's Avatar
so overall, the width is the same, but the usable tread isn't. Depending on what you're using this car for, and how much experience you have with low-profile tires (they tend to BREAK traction without warning) you may be better off with the 205 Azenis.
Basically what you're looking at is a sidewall width difference.
One is ( and the other is |
Old Jun 22, 2007 | 09:54 AM
abnaasefmb's Avatar
Default Re: widest tire??? (drummingpariah)
here is a pic of my car with the bfg's 205/50/15
and here is my car with the falkens 205/50/15
bfg's again
Old Jun 22, 2007 | 10:24 AM
SIred91's Avatar
Rainman
I love your car man....you need to school me on boosting my CRX man
Old Jun 22, 2007 | 10:29 AM
abnaasefmb's Avatar
Default Re: widest tire??? (SIred91)
you know i got your back, Jack! just pm away
Old Jun 22, 2007 | 11:18 AM
clubef9's Avatar
didn't want to start a thread so I'll ask here. Is it possible to run a 15x7.5 with +38mm offset on a 89 hatch? will run 205/50's...
guero2craze
Apr 25, 2007 05:13 PM
SoCal ITR
Apr 12, 2006 07:03 AM
JDM Factor
Jun 7, 2005 01:28 AM
Transport
Suspension & Brakes
Jan 9, 2005 08:28 PM
dgdarien
Jun 4, 2003 06:14 AM
