No more gas money!!! WTF!?!?!?
Old Jun 21, 2007 | 12:03 PM
MDM's Avatar
MDM
Default No more gas money!!! WTF!?!?!?
ive been having a lil situation on gas milage, i got this car last year and was running normal and all of a suddon i started burning a grip of gas!!
i so far changed the Spark Plugs(NGK), Fuel Filter, Cap and Rotor and PCV valve but those foos gave me the one that goes on the B20 so i had to cut that extra piece since i have a D16Y8... im waiting on my Spark Plug Wires(NGK)
but dont know if that'll make a difference?? my fuel pressure regulater is set at 41psi but gunna change it to 45psi...
you guys know what else i can do???????
i need help ive been waisting tooooo much money on gas and have none left for other mods....
THANKS IN ADVANCE!!!!!!!!
Old Jun 21, 2007 | 12:06 PM
93baggedcivic's Avatar
Default Re: No more gas money!!! WTF!?!?!? (MDM)
gas leak poss somewhere
Old Jun 21, 2007 | 12:07 PM
97Ej6mike's Avatar
Gas mileage is affected largely by drivers habits'. The more agressive and faster you drive, the more gas you use up. Also, run the correct oil (on your cap), make sure you have a good and functioning MAP sensor, clean and working O2 sensor, clean fuel filter, and clean injectors. Those, aside from driving habits, also define a large amount in gas milage.
Old Jun 21, 2007 | 12:08 PM
MDM's Avatar
MDM
Default Re: No more gas money!!! WTF!?!?!? (93baggedcivic)
even if i dont smell any gas????
Old Jun 21, 2007 | 12:11 PM
MDM's Avatar
MDM
Default Re: (97Ej6mike)
i cant quote here at work but to -97Ej6mike - what do i claen the o2 sensor with???????
.. i got a new filter and use Lucas for the injectors!
Old Jun 21, 2007 | 12:12 PM
MDM's Avatar
MDM
Default Re: No more gas money!!! WTF!?!?!? (The Lurk Artist)
lurke artist... yea that might be the problem... should i get any o2 sensor? what do u recomend??
Old Jun 21, 2007 | 12:14 PM
yoffer's Avatar
Banned
Any CEL's? I would agree that you o2 sensor is bad. But i would go ahead and replace both of them. I think they are about 100 bucks apiece from Advance.
Old Jun 21, 2007 | 12:16 PM
MDM's Avatar
MDM
Default Re: (yoffer)
nah no CELs after i got the radiator fan switch.. CELs would turn on every other weak because i placed a wire instead of the new sensor but thats gone!
one o2 is in the header and the other one??? after catalic???
Old Jun 21, 2007 | 12:18 PM
EE_Chris's Avatar
Why do you have a fuel pressure regulator?
Old Jun 21, 2007 | 12:22 PM
MDM's Avatar
MDM
Default Re: No more gas money!!! WTF!?!?!? (EE_Chris)
because a came up with one and it looks nice..lol..
ima turbo that sucker after summer so i can remove the a/c.. why is there a problem with the fpr??
Old Jun 21, 2007 | 12:25 PM
97Ej6mike's Avatar
Default Re: (MDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDM &raquo;</TD></TR><TR><TD CLASS="quote">i cant quote here at work but to -97Ej6mike - what do i claen the o2 sensor with???????
Brake cleaner can clean the O2 sensor, but your better off just replacing it if your gas mileage is that bad. Also, check your MAP sensor, make sure its plugged in correctly, and functioning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDM &raquo;</TD></TR><TR><TD CLASS="quote">because a came up with one and it looks nice..lol..
ima turbo that sucker after summer so i can remove the a/c.. why is there a problem with the fpr??</TD></TR></TABLE>
Its good to have an FPR if your planning on boosting, and plan on getting a good tune, but tampering with it on a basically stock motor can certainly deduce your gas mileage if you dont know what you are doing. Leave that stuff to the tuners at the dyno shop.
Old Jun 21, 2007 | 12:28 PM
crazyguy's Avatar
yeah check your o2 sensor.
MDM's Avatar
MDM
97Ej6mike
will do ima clean it meanwhile i get a new one check the map sensor but if its bad how do i know??
Old Jun 21, 2007 | 12:29 PM
yoffer's Avatar
Banned
your second o2 sensor would be after the cat coverter.
Old Jun 21, 2007 | 12:30 PM
EE_Chris's Avatar
Do you have a lot of other mods installed?
Old Jun 21, 2007 | 12:33 PM
97Ej6mike's Avatar
Default Re: (MDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDM &raquo;</TD></TR><TR><TD CLASS="quote">97Ej6mike
Make sure its plugged in, and that you arent getting any Check Engine Lights. If its the stock MAP sensor, and the motor has over 70k miles on it, id look into replacing it, that made a difference when i did it. Their not too expensive. THe unit itself has a tiny nipple hole that is used to detect air flow, in turn, letting the ECU know what amount of fuel to put in. It also helps the idle. Now to check it, make sure the tiny nipple (when the unit is removed) isnt cloged with dust/crud/debris, that would certainly affect gasmileage. It can be cleaned out using a pinch of brake cleaner and a needle or other thin object to free out any debris blocking its tiny air hole. The likelyhood of it being clogged is slim unless you have a vaccuum leak or bad airfilter, or basically any other way foreign objects would make their way to the manifold.
MDM's Avatar
MDM
EE_Chris
not really i got the fpr and gauge, vafc, boost gauge and a/f gauge since i was boosting but didnt fit cause of the a/c condensor but will remove it after summer since its 116 degrees F over here, intake, headers, grounding kit thats it pretty much stock and slow!!
Old Jun 21, 2007 | 12:37 PM
MDM's Avatar
MDM
97Ej6mike
yea its stock and yea it has waaaay more the 70k miles so ima check that and see what i could do since i dont want to spend a lot of money in that SOHC and use it towards my LSVTEC build but i guess if i want it to run good gas milage im gunna have to waste money so ima do it!!!
Old Jun 21, 2007 | 12:51 PM
MDM's Avatar
MDM
Default Re: No more gas money!!! WTF!?!?!? (crazyguy)
crazy guy...
thanks
Old Jun 21, 2007 | 12:52 PM
MDM's Avatar
MDM
Actually thanks to all
Old Jun 21, 2007 | 02:42 PM
Agent_EM1's Avatar
So your not gonna change your O2 sensor? i've see nthe change work wonders
Old Jun 21, 2007 | 02:51 PM
MDM's Avatar
MDM
Default Re: No more gas money!!! WTF!?!?!? (Agent_EM1)
sir agent.. i am gunna change it thats prolly a must on my list! =]
slamLOWnBANGIN
Aug 14, 2010 12:39 AM
IgnitionZ05
Aug 8, 2007 11:50 PM
Oreo-TeCk
Sep 28, 2006 09:30 AM
nver2
Feb 3, 2004 01:27 PM
