wierd miss firing
wierd miss firing
if you can help me solve this i will pay 20 bucks thru paypal!!
when i am in first...i take off...about 2k to 3k rpm is starts spitting/missfiring. it goes like...vrooooooooom..spits spit spits spits...vrooooooooooooooooooooooom. i throw it into second...about the same amount of rpms...it spits maybe once. today i changed out the spark plug wires i thought that was a issue. NOPE. changed the spark plugs...NOPE. i called a couple of friends. 1 said it can be my O2 sensor cuz i installed a header into my car and when we pulled my old O2 sensor..it look black as hell. he said that can be a problem. i thought it was denation cuz i been using crappy gas since i got the car...i started to use mid grade...nope. i called another friend and he said my exhuast piping is too small. i have a ebay n1 exhuast and i am using stock piping. the piping looks really really small...he said that there isnt enough back pressure. another friend said to go buy a engine cleaner which i put half the bottle in my gas tank and the other half where i put my oil at. the day it start happening...i changed my oil and installed a short throw shifter. i went to pick up my little brother from a friends house and the guy house had a upward dip into his driveway but when i was backing out...i scrapped the living SH*T of it. the wierdest thing it only happens really bad in first gear. then pretty much goes away. please help...its very annoying and its scary cuz i dont want my motor to blow. thanx in advance.
Re: wierd miss firing (djviet2000)
and now this morning i would sit in neutral...and my car would jump 1k and up to 1500k rpm without me stepping on the gas...like it was stepping on the pedal for me.
usuall the surge is coused by a vaccum leak another bad problem with them is the egr valves build up alot of carbon try to clean or replace it but make sure u clean the intake tubes use carb cleaner
Re: (95civiccpdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civiccpdx »</TD></TR><TR><TD CLASS="quote">another bad problem with them is the egr valves build up alot of carbon try to clean or replace it but make sure u clean the intake tubes use carb cleaner</TD></TR></TABLE>
EGR valve huh??? find me one on a civic besides a VX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsi401 »</TD></TR><TR><TD CLASS="quote">distributor may be bad i had this same problem and had to change it out ever since ive had no problems
most likely the ignitor, which is in the dizzy, so i agree.
Re: (b16a4)
Allright,
The hesitation/misfire deal might be the EGR ports on the IM (IF YOU HAVE AN EGR), there are ports that go from smaller-larger as they go away form the EGR, this is to make sure that each port gets the same volume of gas in each cyl. clean these out, because the smaller ports get clogged up first and dump all the hot unburnt gasses into one or two cyl.'s. As for the phantom revving, there is a cover on the back of the throttle body that houses the fast idle thermo valve. if you pull the cover off and tighten down a screw inside there it should keep the idle steady, if that doesn't work spray brake cleaner all over the vacuum lines and listen for a change in idle. You should also check the compression on each cyl. and perform a valve adjustment. If you are getting a misfire code try removing the fuel rail and swapping the injector on the misfiring cyl. for a cyl. that is not misfiring to see if the misfire follows the injector.
Hope that helps,
Rad
Hope that helps,
Rad
hey my brother had this proble with his nissian ill ask him when i get a chance to find out what he did to fix it b/c his idel speed would go up and down and someties almost stall out
ShinotakuX
02-07-2008 06:54 AM
