Oil light on bad?
Old Jun 21, 2007 | 06:34 AM
Sfedai0's Avatar
Default Oil light on bad?
Ok this happened a couple weeks ago. The light turned on while on the road and I immeadiately pulled over. Checked and I was def low on oil (prob less than 2 quarts left). Shoulda have realized when vtec wasnt kicking in fully. Changed the oil on the spot. The light went away but Im wondering if I should run any tests or anything of that sort?
Old Jun 21, 2007 | 06:35 AM
walker111's Avatar
Default Re: Oil light on bad? (Sfedai0)
Oil lights on honda's are always bad... Always check your oil!
Old Jun 21, 2007 | 06:38 AM
Mugen Mike's Avatar
Default Re: Oil light on bad? (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">Oil lights on honda's are always bad...</TD></TR></TABLE>
Truth.
Old Jun 21, 2007 | 06:39 AM
Jon D's Avatar
If your V-attack wasn't attacking you were very low
Old Jun 21, 2007 | 07:01 AM
vtec.dc2's Avatar
oil ligts means no pressure
Old Jun 21, 2007 | 07:04 AM
andyt's Avatar
Default Re: Oil light on bad? (Jon D)
Yeah, its pretty bad.
It basically means you are at about a quart of oil left.
I know my oil rings are shot....don't have time to fix it right now
Old Jun 21, 2007 | 07:07 AM
Dave-ROR's Avatar
Default Re: Oil light on bad? (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">oil ligts means no pressure</TD></TR></TABLE>
Well 3PSI or so, but yeah, usually means time for some work...
Old Jun 21, 2007 | 07:16 AM
vtec2nv's Avatar
Default Re: Oil light on bad? (Dave-ROR)
well as long as the car is running fine you should be good. pulling over the second the light came on was the smartest thing u did You got lucky try not to push ur luck next time. Check ur oil atleast once a week.
Old Jun 21, 2007 | 07:22 AM
JjuuN R's Avatar
Default Re: Oil light on bad? (vtec2nv)
Plus... if your oil light came on you were definitely down way more then 2 quarts.
Old Jun 21, 2007 | 07:26 AM
Ed 341's Avatar
Does the car usually use a lot of oil? How many miles?
Old Jun 21, 2007 | 07:33 AM
Sfedai0's Avatar
Im at 32k but I ran the full 5k limit for the recommended synth oil change. Cant say I was suprised bout this since I had been mad V-takking. Just suprised this car burns so much oil. Lesson learned. Came back from Expo and Im down to the first hole on the dip. Goin to Castrol Synth to see if it helps.
Old Jun 21, 2007 | 07:46 AM
Ed 341's Avatar
Default Re: (Sfedai0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sfedai0 &raquo;</TD></TR><TR><TD CLASS="quote"> Came back from Expo and Im down to the first hole on the dip. Goin to Castrol Synth to see if it helps.</TD></TR></TABLE>
Wow, thats almost as bad as mine and I have 100,000 more miles! You should check for leaks, especially around the dip-stick area.
Old Jun 21, 2007 | 07:50 AM
Sfedai0's Avatar
No sign of any oil leak and I did drive it pretty hard at Expo so Im not suprised to see it a bit low.
Old Jun 21, 2007 | 12:59 PM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
I followed you for a bit at the PA meet and your car needs rings f*cking BAD. Like following a bug sprayer.
Old Jun 21, 2007 | 02:30 PM
dsav4shawn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sfedai0 &raquo;</TD></TR><TR><TD CLASS="quote">...I immeadiately pulled over. Checked and I was def low on oil (prob less than 2 quarts left)... Changed the oil on the spot.... </TD></TR></TABLE>
Mine did the same thing... then I had a spun rod bearing shortly there after (within 5-10K). GL on the rebuild. ALWAYS check your oil... it doesn't take that long.
mtownek9
Apr 1, 2008 01:54 PM
motormike40
Aug 21, 2006 06:02 PM
DC_RaceR
Feb 23, 2006 02:00 PM
hillbillybob
Feb 9, 2005 07:05 AM
Foxcow
10
Dec 16, 2004 08:56 PM
