O2 questions on d15b into vx swap??
Old Jun 20, 2007 | 10:26 PM
thehondaconnection's Avatar
Default O2 questions on d15b into vx swap??
which O2 do I use?going to be using a P08 ecu.I dont do much single cam work,mostly B series.94 vx.I cant use the existing O2 right?I'm not looking at the car but arent there more than 4 wires?Am I supposed to switch to a one wire,four wire or the one with more than 4 wires?should I just switch to a d16z6 harness,or should I just hardwire it,if so can someone lead me to some pinouts.
Old Jun 21, 2007 | 01:36 AM
92_VX_EG's Avatar
Default Re: O2 questions on d15b into vx swap?? (thehondaconnection)
I'd use another harness besides the stock VX harness. It uses a 5-wire o2 sensor and I'm guessing that you have the 130hp Vtec D15B which uses a 4-wire. If you use a Z6 harness all you have to do is this to get ECU signal and no code 1's: https://honda-tech.com/zerothread?id=644434. You only have to remove the o2 sensor one. Disregard the knock sensor and secondary runners since you have no need for them to be wired.
f22vx
Jan 24, 2011 07:33 PM
dturbo
Jun 8, 2005 06:16 PM
ChrisDaun
Feb 12, 2004 04:25 AM
TriK
Jul 2, 2003 10:56 AM
