what are some things i should but to up my fuel for turbo on my b18b
Old Jun 5, 2002 | 08:39 PM
mracura's Avatar
Default what are some things i should buy to up my fuel for turbo on my b18b
i'm new to the turbo thing and just blew my motor i think because of lack of fuel so, what are some products or what i can use to fix the problem? if u dont mind can u be specific on what each thing does, talk to me like i'm stupid i dont mind i'm learning. i appreciate any help. thanks.
[Modified by mracura, 5:39 AM 6/6/2002]
Old Jun 5, 2002 | 09:47 PM
93LSivic's Avatar
Default Re: what are some things i should buy to up my fuel for turbo on my b18b (mracura)
Mracura, have you met mrsearch? https://honda-tech.com/zerosearch
Old Jun 5, 2002 | 09:54 PM
turbopanda's Avatar
yes, use the search feature
but to get you on the right track, so you know what to SEARCH for.. you need a good set of forged rods and pistons, lowered engine compression ratio, blockguard, good fuel pumps, bigger fuel injectors, and last but not least, STANDALONE ENGINE MANAGEMENT. If you have all of these.. you car should run smoothly and be a lot more stronger under boost.. you should be able to push more boost with all the things mentioned above too Almost everyone on this board praises Hondata for engine management, personally I think otherwise. If you're in the US, you may as well go with Hondata simply because a lot of shops know how to tune them well
trammell89
Jan 12, 2007 03:30 PM
variablevalve
15
Dec 25, 2002 07:47 PM
boostinb18
May 17, 2002 12:27 PM
jdmotorsports
Jul 3, 2001 05:54 PM
DR. ON POINT
Jun 27, 2001 06:25 PM
