fuel pressure on B18b turbo???
hey everybody!
I just bought a B&M fpr from my friend with the fuel guage and i want to throw it on my turbo ls crx.......what is a good fuel pressure to set it at?? im boostin about 6 pis.
thanks a lot!
thanks a lot!
Re: fuel pressure on B18b turbo??? (boostinb18)
i am not a genius inthe area but static fuel pressure (idle)should be from 40-50 psi.....but with an fmu under boost....it will raise the fuel press. whatever rise rate u r running...ie
10:1 at 6 psi will raise the fuel press under boost to 60psi plus stock.......the bm is mainly to asjust idel fuel press, static.
but do a search, this is a lamain's term example.....it gets much more in depth than this.
danno33
12-27-2006 02:16 PM
