Question about Injectors
Old Jun 20, 2007 | 07:02 PM
90 Si Hatch's Avatar
Default Question about Injectors
so i spun a rod bearing in my Y8 motor well when i was tearing down the motor after i had taken it out of the car, i droped 2 of my injectors on the shop floor and cracked that bottom plastic pice (obd-0 si)... well i picked up a complete D15B vtec yesterday and it came with obd-1 injectors. so my question is can i use these obd-1 injectors since i'm still using the injector resistor box???
Thanks, Isaac-
Modified by 90 Si Hatch at 6:37 PM 6/21/2007
Old Jun 20, 2007 | 07:03 PM
yz125rider21's Avatar
NO...pretty sure it well melt the injectors cause obd1 are saturated.
Old Jun 20, 2007 | 07:09 PM
Default Re: Question about Injectors (abnaasefmb)
okay well if it wont work, how do i wire them up with out the resistor box?
99teggsr's Avatar
ur gonna have to get rid of the resistor box and get some obd1 injector clips and wire them in..theres a good article somewhere on the net for this, i will try and find it for u
Old Jun 20, 2007 | 07:21 PM
Default Re: Question about Injectors (99teggsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99teggsr &raquo;</TD></TR><TR><TD CLASS="quote">ur gonna have to get rid of the resistor box and get some obd1 injector clips and wire them in..theres a good article somewhere on the net for this, i will try and find it for u </TD></TR></TABLE>
when i bought the D15B it came wtih the cut harness so i have the injectors and the clips....
Old Jun 20, 2007 | 07:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">its too easy, there is a cap you can get or just solder all the wires that went to the box together</TD></TR></TABLE>
Solder "ALL" the wires that went to the resistor box together?
Old Jun 20, 2007 | 07:48 PM
yes the car is an Si... and tell me abou this cap your talking about?
Old Jun 21, 2007 | 10:24 AM
So any one else have an idea on this subject. or is he right?
Old Jun 21, 2007 | 10:40 AM
Bob_760's Avatar
Default Re: Question about Injectors (90 Si Hatch)
Yeah hes right about the resistor box, also I'm pretty sure OBD-0 and OBD-1 injector clips are interchangable.
Old Jun 21, 2007 | 11:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">yes he's right! </TD></TR></TABLE>
LoL
Old Jun 21, 2007 | 12:16 PM
dem0nk1d's Avatar
obd1 injectors will work with a obd0 system correctly, if the resistor box is removed. the cap style, is used on all 92-95 civics...
Old Jun 21, 2007 | 12:24 PM
EFM_ookie's Avatar
Default Re: (dem0nk1d)
u can file off a little bit of the injector to make the obd0 clips work
Old Jun 21, 2007 | 05:36 PM
Default Re: (89_Mangina_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
so where can i get one of these at, i want it looking clean as i can get it!
Old Jun 21, 2007 | 08:37 PM
STREETWERKZ's Avatar
LOL at the PM in the background with borat.
BTW, the injectors that you dropped, are still usable. the plastic piece you speak of are there to protect the injector tips.
just dont drop them again.
Randysi
Apr 4, 2012 10:17 AM
pinecone
Apr 25, 2006 06:41 AM
killa rex
Jan 25, 2006 02:54 AM
e jay one
Aug 6, 2005 02:48 PM
