F22b2 Turbo injectors ?
Old Jun 20, 2007 | 05:32 PM
NeKe1point0's Avatar
Default F22b2 Turbo injectors ?
F22b2 obd1 peak and hold low impedence right ? should i go with RC 550's 750's ? or DSM 450's ? How much mod'ing to the gaskets for the DSM's if anyone has run these ? looking at a final output of 350hp... u know how it is u can never go fast enough
Old Jun 20, 2007 | 06:51 PM
JDM_Acccord's Avatar
Default Re: F22b2 Turbo injectors ? (NeKe1point0)
550cc should be fine
Old Jun 21, 2007 | 08:34 AM
raceACCORDingly's Avatar
yeah 550's are good.
450's will max out at just around 300hp.
http://homemadeturbo.com/tech_....html
Old Jun 21, 2007 | 08:55 AM
Andryzzle's Avatar
Default Re: (raceACCORDingly)
dont you want saturated injectors?
Old Jun 21, 2007 | 09:55 AM
Default Re: (Andryzzle)
F22b2 obd1 peak and hold low impedence right ? ?
Old Jun 21, 2007 | 10:52 AM
Andryzzle's Avatar
Default Re: (NeKe1point0)
i dont remember, thats why i wanted to double check
Old Jun 21, 2007 | 12:58 PM
Old Jun 21, 2007 | 01:26 PM
dsm 450's are peak and hold. 90-97 accord are also the same we have a resister box from factory.
Old Jun 22, 2007 | 06:14 AM
twkdCD595's Avatar
I have run dsms and they are very easy to mod the seals to make fit properly... just takes a few minutes with a dremel or little grinding stone/ high speed drill to open them up.
but I will tell you that 450cc injectors will not carry 350whp but will just bearly carry 350 crank hp... I saw 450's max out with 335whp/280ft. lbs. on my old setup, that was with a bit of added fuel pressure (stock regulator added pressure when it sees boost 1:1 I believe).
Old Jun 22, 2007 | 09:49 AM
Default Re: (twkdCD595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">I have run dsms and they are very easy to mod the seals to make fit properly... just takes a few minutes with a dremel or little grinding stone/ high speed drill to open them up.
yeah ... I saw the guide on here looks easy enough.
but I will tell you that 450cc injectors will not carry 350whp but will just bearly carry 350 crank hp... I saw 450's max out with 335whp/280ft. lbs. on my old setup, that was with a bit of added fuel pressure (stock regulator added pressure when it sees boost 1:1 I believe).</TD></TR></TABLE>
- i have heard this from more than one person now, but abt the fpr, i was thinking b&m fpr = $80, any other good reccmndations fuel rail/fpr for good price ?? if not its cool heard good things abt the b&m for the price. defntly appreciate the info
csmith21
Mar 12, 2013 01:43 AM
accordin 2 me
Dec 16, 2011 06:00 AM
LSV_REX
May 28, 2008 06:41 AM
CaptinMcnut
Mar 1, 2004 02:01 PM
