89 CRX HF LS VTEC swap won't start??
Old Jun 20, 2007 | 03:22 PM
DrPerformance's Avatar
Default 89 CRX HF LS VTEC swap won't start??
I have an LS Vtec swap in my 89 CRX HF , it is a 96 GSR head 91 LS block. It has spark, fuel press. & Volume, Injector pulse, plug wires correct, distributor ok, etc... It has everything there but won't start. It won't crank from the key but will if you jump the starter solenoid. There are no ecu codes either? The car is running OBD0 I haven't changed any sensors but I shouldn't have to?? Some one have any ideas?? I have no clue??
DR
Old Jun 20, 2007 | 03:38 PM
SIXTY's Avatar
Default Re: 89 CRX HF LS VTEC swap won't start?? (DrPerformance)
what kind of distributor are you using?
Old Jun 20, 2007 | 03:47 PM
TD44U
Old Jun 20, 2007 | 03:49 PM
SIXTY's Avatar
Default Re: (DrPerformance)
Well, i am not familiar with part numbers, but if that is an obd1 distributor, and you are using an obd0 computer, that could be your problem.
Old Jun 20, 2007 | 03:52 PM
Why is that? Everything is wired correctly, it is off a 96 type-r. I am almost positive as long as you match wires color for color you can use any B series Dist.
Old Jun 20, 2007 | 04:02 PM
SIXTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrPerformance &raquo;</TD></TR><TR><TD CLASS="quote">Why is that? Everything is wired correctly, it is off a 96 type-r. I am almost positive as long as you match wires color for color you can use any B series Dist. </TD></TR></TABLE>
Well, i am almost positive that you cannot. The internals are completly different.
Old Jun 20, 2007 | 04:04 PM
No they are the same?? The difference is the plugs?? Can anyone else elaborate on this?? I have also tried several other Dist. also. Plus there are no codes CKP, TDC etc.. if there were then it would point to the dist.
Modified by DrPerformance at 6:17 PM 6/20/2007
Old Jun 20, 2007 | 05:12 PM
Haza45's Avatar
You cannot use an obd1 dizzy with an obd 0 ecu. However you can use an obd 2 ecu in an obd1 car and vice versa just the plugs are diff.
Check your grounds. From the Tranny to the frame and the VC to Frame.
Old Jun 20, 2007 | 05:19 PM
Ok the gears inside are different, but would this keep it from starting?
Modified by DrPerformance at 9:11 PM 6/20/2007
Old Jun 22, 2007 | 12:36 PM
mahatma's Avatar
get the right distributor!!
Old Jun 24, 2007 | 05:28 AM
alterdcreations's Avatar
Default Re: 89 CRX HF LS VTEC swap won't start?? (mahatma)
also the injectors are different. use the obd0 injectors if you kept the resistor box
Old Aug 2, 2010 | 07:44 PM
me_moe_joe's Avatar
It all comes down to how many pulses per second is why they are different from obd1 to obd0.
deltazlt
May 23, 2013 02:17 AM
Vadim_D
Jun 9, 2010 06:09 AM
hanford_rex2
Feb 28, 2008 06:41 PM
AMG
Aug 6, 2003 10:32 AM
AMG
Aug 6, 2003 08:56 AM
