too much oil in crankcase
well my car has over 800 miles on it and i just found out that there is to much oil in the crankcase. i read the manual and it said should be between upper and lower marks. mine is full on a cold engine that wasnt started for over 2 days. Outside temp. is around 80 issh but in the garage its probably more. what should i do drain some out.?
ps its a LX. here is a pic
It looks as though your oil level is at the full mark, which is perfectly fine. Keep in mind that the oil level in the pan will fall once oil begins to pump through the engine. Honda states that an "acceptable" oil level falls between the upper and lower marks on th dipstick. This basically means that a full level is desired, but anything between the level marks on the dipstick is OK.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulli Kid »</TD></TR><TR><TD CLASS="quote">bumpp . still unsure</TD></TR></TABLE>
What are you unsure about? Your oil level is at Full. Would you be happier if you had less than full?
You are at full after letting basically all of your oil drain into the pan (2 days sitting). You are fine, even if you were at full after beating on your car you would be fine IMO. Nothing to worry about at all, especially with the break in oil still in there.
Jon
Jon
Any level on the dipstick that falls between the upper and lower marks, including at the full mark, is considered acceptable. Just look at it in the same way that you look at the level in your gas tank. A full tank of gas is best, but you are OK up to the point that your low gas light comes on. Leave the oil alone....enough said!
i dont have the instructions and im always basing on the computer but just to make sure how much should my oil levels be on the XXXXXX well x's lol ? does it have to be at the top where the last X is at or in between or what? again i dont have the manuel so i cant read it ..... would really apriciate it
mobile 1 full sny R18 2,5xxx miles yes 2 thousand changed from oem oil in 1,3xx someting. automatic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gus738 »</TD></TR><TR><TD CLASS="quote">
mobile 1 full sny R18 2,5xxx miles yes 2 thousand changed from oem oil in 1,3xx someting. automatic</TD></TR></TABLE>
I don't have my decoder so I'm not sure what you're saying but it looks like you changed your oil at 2000 miles? On the first change? What was the rush to get the break in oil out?
yes i changed the oil after 1, 3 xx something miles to mobile 1 full snyc but my question is how much should i be looking at the engine oil reading? should it pass all the XXXXX or be in middle of x's? i dont have the manuel so thats why i asked so i can know the proper amount of oil needed.
ps : was it hard or confusing to read my previous post?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gus738 »</TD></TR><TR><TD CLASS="quote">yes i changed the oil after 1, 3 xx something miles to mobile 1 full snyc but my question is how much should i be looking at the engine oil reading? should it pass all the XXXXX or be in middle of x's? </TD></TR></TABLE>
Nx, I Dxx't Txxxk Hx Dxd!!!
LOLZ!!!
LOLZ!!!
GoLowDrew
Jul 31, 2006 07:10 AM
kegard
32
May 30, 2005 12:12 AM
