Sheet metal source??
Old Jun 20, 2007 | 08:44 AM
29psiHybrid's Avatar
Default Sheet metal source??
Wheres a good place to get sheet metal? I've been looking around for a piece of 3'x2' either 1/8" aluminum or 16ga. stainless and cheapest I've found is around $80
Old Jun 20, 2007 | 11:08 AM
tepid1's Avatar
Default Re: Sheet metal source?? (29psiHybrid)
What's ths for?
What grade AL or SS?
I can get 6061 T6 2'x3' for $74. That's an online vendor too. Go to a metal yard and you can get it cheaper I'm sure.
Old Jun 20, 2007 | 12:31 PM
Bakeoff's Avatar
Start calling around. There will be a ton of places to call, but if you tell them you're just looking for one small piece, they'll probably give you the name of the cheapest place around. Most of the steel guys are pretty cool.
I know at the metal yard I go to, I could get that same piece for close to half that price.
Old Jun 20, 2007 | 01:32 PM
Default Re: Sheet metal source?? (tepid1)
I was going to use it to build a catch can/overflow can. Was planning on 6061 or maybe 7075. I was just assuming they were overcharging me because I live in a small town but if you say $74 is a normal/good price, I don't feel as bad paying that much I guess. Thanks for the help!
Old Jun 20, 2007 | 02:30 PM
k24em2's Avatar
You could probably buy a full sheet and just cut it yourself.
Old Jun 20, 2007 | 07:20 PM
dfoxengr's Avatar
you dont want to weld 7075, stick with 6061
Old Jun 20, 2007 | 08:58 PM
iBrandon's Avatar
Default Re: Sheet metal source?? (dfoxengr)
i built one like tony's 1, the aluminum sheet metal (6061) costed me under 25 bucks...at our local Metal Supermarket shop...
what kills u is the dam aluminum bungs, their around 6-9 bucks a piece depending the -an size and brand. And when u get like 6 bungs welded on there...(2 for front of valve cover, 2 for rear, and 2 for the return...and then 4 more for the valve cover and 2 for the return on the back of the block...thats 12 all together, **** adds up...
plus u still need to buy the filters, which are around 10 bucks a peice...so depending how you want your system set up..its not cheap! haha..and thats without the ss hose and hose fittings..
Also if anyone knows where i can buy those aluminum bungs in bulk please feel free to share!
Old Jun 20, 2007 | 09:42 PM
TurbochargedInnovation's Avatar
Default Re: Sheet metal source?? (iBrandon)
http://www.racepartsolutions.com
http://www.racepartsolutions.c...at=20
Little over $5 bucks a pop, and even cheaper if your in good with them!
Old Jun 24, 2007 | 02:36 AM
ROTARY's Avatar
i get a lot of my aluminum from http://www.aircraftspruce.com , good prices and shipping is fast.
Old Jun 24, 2007 | 02:41 PM
Howitt's Avatar
Default Re: (ROTARY)
Im sure I could beat those prices on bungs, I just dont have time to run the cnc lathe if I could find me a push button operator for cheap, ht would have cheap parts
a267mm
Welding / Fabrication
16
Mar 23, 2013 05:17 AM
SR20S13
Jan 26, 2012 04:06 AM
EdsGTI
Mar 21, 2008 02:09 PM
drummr6
Oct 7, 2007 06:36 PM
HamiltonRex
21
May 24, 2006 09:20 AM
