I Need Help A.S.A.P PLEASE!!!
Old Jun 20, 2007 | 08:02 AM
iheartmyef's Avatar
Default I Need Help A.S.A.P PLEASE!!!
ok i deffinetly need some help and fast...
Ive got a '91 civic hatch with a b18b, its got a built head with cams, cam gears, valve springs/retainers, intake mani, throttle body. It idles rough cause of the cams, but yesterday as i was driving to a buddies the check engine light came and it started to run really rough, more than usuall. i got to my friends house pulled the fuse for the ecu to reset the light. the light went out but now the car idles rougher than **** and has absolutely no power. i mean my buddies worn out z6 could spank me all day.
I pulled the plugs and checked them, they were alittle fouled so i cleaned the up, put them back in. pulled the cap off the dizzy and the inside of the cap had a bunch of like red powder and metal shavings, i cleaned that up through it back on started the car up and still no power, and this time the tach stopped working. the car will be moving but the tach needle stays at 0.
Please help!!! this is my daily driver and i need to get her up and running right again.
Thanks
Old Jun 20, 2007 | 08:04 AM
mahatma's Avatar
Default Re: I Need Help A.S.A.P PLEASE!!! (iheartmyef)
gotta be distributor.
Old Jun 20, 2007 | 08:05 AM
philkehn's Avatar
sounds like your distributor is going bad? maybe just a new rotor?
Old Jun 20, 2007 | 08:08 AM
iheartmyef's Avatar
Thats what i was thinking... i just converted the car to obd-1 and the dizzy i bought from some tweaker had wires cut on the inside that i had to put back together.
But me buddy at toyota said to check the ignition coil in the dizzy... does that sound right?
and thanks for the quick replies
Old Jun 20, 2007 | 08:09 AM
accord91guy's Avatar
distributer or maybe timing is off
Old Jun 20, 2007 | 08:13 AM
JustAnotherRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartmyef &raquo;</TD></TR><TR><TD CLASS="quote">Thats what i was thinking... i just converted the car to obd-1 and the dizzy i bought from some tweaker had wires cut on the inside that i had to put back together.
and thanks for the quick replies </TD></TR></TABLE>
If you've got metal shavings in there, then yes, I would try changing out the ignition coil if the distributor isn't that high in mileage, if it already isn't in great shape, I'd try to hunt down one that's known good for around 100-140 and just buckle down so you know it'll be reliable from there on out.
Good luck.
Old Jun 20, 2007 | 08:21 AM
alscrx's Avatar
Default Re: I Need Help A.S.A.P PLEASE!!! (JustAnotherRex)
I had a crx with same problems, Opened dizzy cap and found metal shavings or like metal copper wires. Went and ordered a rebuilt dizzy and it came with new coil and ignitor. Fixed the problem 100%
Old Jun 20, 2007 | 08:24 AM
iheartmyef's Avatar
Right on thanks everyone for the quick responses... have any of you guys heard of the distributor king online? my buddy told me that they sell new factory honda dizzy's that are race ready for heat or something... if anyone's tried them then let me know.
Old Jun 20, 2007 | 11:23 AM
rustbucketrex's Avatar
Default Re: (iheartmyef)
Distributor King I'm happy with mine. $139 through EBAY shipped. But mine was for a
TD-02 for a SOHC.
Old Jun 20, 2007 | 12:30 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (rustbucketrex)
i second the for distributor king..
metal shavings usually mean your distributor bearing is going bad.
Old Jun 20, 2007 | 02:06 PM
ChickenH's Avatar
http://www.DISTRIBUTORKING.com
the distributor shaft bearing is going out making the shaft flop around. the shavings get in the way of the reluctor sensors for tdc cyl sensor etc.. or it flops enough to mess up the sensing.
Old Jun 20, 2007 | 05:44 PM
Crx Jimmy's Avatar
Default Re: (ChickenH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChickenH &raquo;</TD></TR><TR><TD CLASS="quote">http://www.DISTRIBUTORKING.com
the distributor shaft bearing is going out making the shaft flop around. the shavings get in the way of the reluctor sensors for tdc cyl sensor etc.. or it flops enough to mess up the sensing.</TD></TR></TABLE>
I dont think that site has worked in awhile, I think he sells out of his ebay store now. His auctions have a phone # to call I think he takes credit cards over the phone, Only took 2 days for my dizzy king dizzy to get to me
Old Jun 21, 2007 | 07:00 AM
alscrx's Avatar
I'll tell you Distributor king is pretty good and you can call and speak to someone if you want. Ebay lists there number. I got my dizzy from autozone for like 240. I saw the DK dizzy and bought that one. Returned mine to autozone. They were way too much for that but i was in a jam. DK is the way to go!! Its like 130 or close to it on ebay! Go for it...
dboysi03
Mar 28, 2010 02:20 PM
20_00_lude
Mar 28, 2009 08:02 PM
namewasdallas
Mar 20, 2008 10:59 AM
kaneda3
Nov 17, 2006 12:12 AM
accordfan
Oct 29, 2002 07:02 PM
