Can i run 100% water?
Old Jun 19, 2007 | 10:31 PM
Obama's Avatar
Default Can i run 100% water?
can you run 100% water in the summer? i just did a flush and my new radiator is on the way. but i need the car tom. is ok to run it like this for 1 day?
Old Jun 19, 2007 | 10:33 PM
pprowler6's Avatar
Default Re: Can i run 100% water? (b0l0)
if its ice water
Old Jun 19, 2007 | 10:44 PM
avallach's Avatar
It's OK. Just make sure you flush it out and replace it with a Honda coolant/water mixture as soon as you can.
Old Jun 19, 2007 | 10:48 PM
piggydog's Avatar
Default Re: Can i run 100% water? (avallach)
100% distilled will keep it cooler than any coolant. It probably isn't going to be good long term but a few days or weeks isn't going to matter
Old Jun 19, 2007 | 10:54 PM
Prudz_lude's Avatar
Default Re: Can i run 100% water? (piggydog)
just curious, shouldn't it evaporate?
Old Jun 19, 2007 | 11:02 PM
fast_honda's Avatar
Default Re: Can i run 100% water? (Prudz_lude)
Just keep in mind that boiling point for water is 212 degrees, MUCH lower than a 50/50 solution, and what do you think would happen if the water boiled? It just depends on where that pressure is released first, whether it be your radiator cap or a coolant passage in your block.
Old Jun 20, 2007 | 02:36 AM
117's Avatar
117
I wouldn't run 100% water. If you want to do that, make sure you add some water pump lubricant. The water pump is lubricated by the coolant.
I use 100% distilled water and Red Line Water Wetter in my track car, as traditional coolant is not allowed. Water Wetter includes water pump lubricant. It works fine for me.
Old Jun 20, 2007 | 08:10 AM
98vtec's Avatar
moderator emeritus
Default Re: (117)
did you see any ECT drop Billy?
Old Jun 20, 2007 | 08:26 AM
mgags7's Avatar
lol blake I need to put that **** about PMs in my sig too
billy what ratio of water to Water Wetter do you use?
Old Jun 20, 2007 | 08:44 AM
98vtec's Avatar
moderator emeritus
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">lol blake I need to put that **** about PMs in my sig too
billy what ratio of water to Water Wetter do you use?</TD></TR></TABLE>
it works, plus not being signed up for a long time helps too.
Old Jun 20, 2007 | 09:53 AM
95greenlude's Avatar
Default Re: (98vtec)
i know that a lot of people here use pure distilled water and 2 bottles of water wetter
Old Jun 20, 2007 | 09:57 AM
117's Avatar
117
My engine stays right around 180F to 200F with a Fluidyne rad, 100% distilled water, and 1 bottle of water wetter. This is at WOT for 20 minutes in the Texas heat.
I have no coolant lines outside of the engine other than the radiator inlet/outlet. The stock oil cooler has been removed and all coolant lines plugged. I doubt these changes make much, if any, difference in cooling, though.
Note that I do NOT run any ducting or radiator fans. I run a stock thermostat, and a 25 row oil cooler, although the oil cooler probably doesn't do much for the coolant temps.
Old Jun 20, 2007 | 12:40 PM
xxmastermindxx's Avatar
Default Re: Can i run 100% water? (fast_honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast_honda &raquo;</TD></TR><TR><TD CLASS="quote">Just keep in mind that boiling point for water is 212 degrees, MUCH lower than a 50/50 solution, and what do you think would happen if the water boiled? It just depends on where that pressure is released first, whether it be your radiator cap or a coolant passage in your block.</TD></TR></TABLE>
water under pressure has a higher boiling point. that's why the coolant system is sealed.
Old Jun 20, 2007 | 12:46 PM
vinuneuro's Avatar
Default Re: Can i run 100% water? (xxmastermindxx)
Make sure you use distilled water if you decide to go the water+waterwetter/similar route.
Old Jun 20, 2007 | 12:52 PM
lmananT's Avatar
will it rust or corrode the block with 100% water?
Old Jun 20, 2007 | 12:54 PM
nonvteclude's Avatar
Default Re: (lmananT)
the block is aluminum so i doubt it will rust the block
Old Jun 20, 2007 | 12:55 PM
vinuneuro's Avatar
Anything other than 100% distilled water will leave deposits in the cooling system.
Old Jun 20, 2007 | 12:57 PM
93sivtec's Avatar
For the short time no,It could if just water is used for a long period of time.Definately use water wetter or coolant in the summer,water alone will not stand up to the summer heat.
Old Jun 20, 2007 | 01:01 PM
117's Avatar
117
My understanding is the water pump is lubricated by the coolant (water, water/coolant, water/water wetter). If you run straight water, there is no lubricant for the water pump. You can buy water pump lube to add to 100% water, but I'd just use water wetter from Red Line.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmananT &raquo;</TD></TR><TR><TD CLASS="quote">will it rust or corrode the block with 100% water?</TD></TR></TABLE>
Old Jun 20, 2007 | 01:05 PM
117's Avatar
117
Default Re: (93sivtec)
The amount of water wetter is so little compared to the entire cooling system that I doubt there is much boiling temp difference between 100% water and 100% water + water wetter. Maybe 3 to 5 degrees F.
50/50 Coolant/water will raise the boiling temp about 11F. The pressure alone adds a whopping 40F to the boiling temp, so by far the pressure is the important of the two. http://auto.howstuffworks.com/cooling-system3.htm
I cannot run any coolant due to rules, and my engine has no problems cooling, but I use a large Al radiator too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93sivtec &raquo;</TD></TR><TR><TD CLASS="quote">For the short time no,It could if just water is used for a long period of time.Definately use water wetter or coolant in the summer,water alone will not stand up to the summer heat.</TD></TR></TABLE>
Old Jun 20, 2007 | 07:10 PM
lude98SH's Avatar
but when u pressurize the water the boiling point goes up. Therefore your boiling point is no longer 212
AudioFunk
Jul 14, 2014 01:15 PM
Osokwik
Feb 22, 2004 08:45 AM
05 600RR
Jul 17, 2002 11:56 AM
onyx00
Oct 29, 2001 09:23 AM
siisgood00
21
Oct 18, 2001 01:14 PM
