Eradic Tach!1!1!!!
Old Jun 19, 2007 | 07:43 PM
crxb16ftw's Avatar
Default Eradic Tach!1!1!!!
I have a 90 CRX w/ b16a swap. The factory tach had been acting crazy. I assumed that the tach had just gone bad, so I purchased a new Auto Meter tach (wanted one anyway). I plugged it into the coil (not the factory tach wire). Now, the Auto Meter tach acts even crazier than the factory tach. At idle, the tach will fluctuate between 1 and 8 grand! It was so annoying, that i just unhooked it. Anyone have a clue of what the root of the problem could be? Coil or distributor issue maybe???
Thanks
Old Jun 19, 2007 | 07:55 PM
REDBARON's Avatar
Default Re: Eradic Tach!1!1!!! (crxb16ftw)
Check your coil but I think it might be the distributor. My bro had a similar problem and it was the dizzy.
Old Jun 19, 2007 | 08:28 PM
89s1's Avatar
Default Re: Eradic Tach!1!1!!! (REDBARON)
My tach started to do that after a little while being pinned by the b16.
people always tell me it means my ignitor is going bad, but it worked fine for me daily.
Old Jun 19, 2007 | 08:34 PM
slow_rex_will's Avatar
Check your ignitor!
Old Jun 19, 2007 | 08:35 PM
Hamstr323's Avatar
Default Re: Eradic Tach!1!1!!! (slow_rex_will)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_rex_will &raquo;</TD></TR><TR><TD CLASS="quote">Check your ignitor!</TD></TR></TABLE>
Old Jun 19, 2007 | 09:15 PM
sirhavok's Avatar
had the same problem and it was my dizzy
Old Jun 20, 2007 | 06:29 AM
boosted timebomb's Avatar
Default Re: (sirhavok)
make sure the two screws are tight on your coil. my car did the same thing and thats all it was
Old Jun 20, 2007 | 11:00 AM
LilJonWask's Avatar
Default Re: (boosted timebomb)
Sounds just like when my ignitor went out. Its inside the dizzy.
Get one from autozone. Its the cheapest place to get it, and it comes with a little thing of thermal paste. Plus it comes with a lifetime warranty.
Old Jun 20, 2007 | 11:20 AM
crxb16ftw's Avatar
Default Re: (LilJonWask)
preciate it.
Old Jun 20, 2007 | 12:02 PM
89efDUSTY's Avatar
Default Re: (crxb16ftw)
also it could be one of the lamest reasons, but if your distirbutor bolts are not tight that will cause it to shake and idle funny.
lexusgui
Jul 27, 2008 07:54 PM
type Gendy
Nov 12, 2004 04:38 PM
WhiteEG6
May 25, 2004 09:51 AM
WhiteEG6
May 20, 2004 03:57 AM
