a little help with my SH suspension (searched)
Hey, i was just wondering if someone could help me with my problem, i have a 99 SH, and i've put in my suspension in my Base prelude before, but i've never run into this problem.
I'm trying to take out the bottom bolt (17mm) by the fork, but theres this "radius rod" thing blocking the way. I really dont' feel like taking it off since there hasn't been a reason to in my other prelude, but just thought i'd ask for advice on the forums.
Thats the rod for reference
closer up
Bam blockage.
I've tried jacking up the brake rotor to see if it would move, it doesn't budge, i've also tried to step on the rotor itself to push it down, it doesn't work either. Kinda clueless, Any help would be greatly appreciated, thanks
closer up
Bam blockage.
You need to disconnect the radius rod balljoint to get at the fork bolt.
How'r you putting the SH suspension in the Base? You'd need the SH subframe for that to work. Or are you just swapping the shocks/springs..
^^^ i'm putting in Teins, so thats why they're interchangable.
I was just hoping not to have to take off that arm. Thanks for the help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro »</TD></TR><TR><TD CLASS="quote">You don't have to take off the arm. Just pop the ball joint and put it back when you're done.</TD></TR></TABLE>
best way
best way
Casco
11
Oct 8, 2008 08:59 PM
