crx ls vtec help please
Old Jun 19, 2007 | 09:46 AM
crxlsvtec01's Avatar
Default crx ls vtec help please
have an 89 crx si 90ls block 94 gsr head have 94 gsr dizzy have obd0-obd1 jumper for ecu n dizzy has 450 injecters si harness with resistor box has skunk 2 intake manifold n68 ml throttle body with the electronic map sensor gettin no fuel or spark using p28 obd1 ecu
Old Jun 19, 2007 | 10:18 AM
jedb18's Avatar
Default Re: crx ls vtec help please (crxlsvtec01)
Ground on theremostat housing?
Old Jun 19, 2007 | 10:20 AM
ne3ek's Avatar
Default Re: crx ls vtec help please (jedb18)
could be a ton of things.. fuel pump turning on at all? Most likely a bad ground.
btw.. 450 injectors? boosted??
Old Jun 19, 2007 | 11:20 AM
Default Re: crx ls vtec help please (ne3ek)
was boooosted. some one told me need to take resister box off? all the grounds are good.
Old Jun 19, 2007 | 01:55 PM
jedb18's Avatar
If you have OBD1 or OBD2 injectors then you don't need the resistor box
Old Jun 19, 2007 | 03:20 PM
4g hatch's Avatar
are they dsm 450's then u need the resistor box. if they are saturated take it off. sounds like a bad ground. cheak the thermostat and all the other grounds like valvecover,and tranny.
Old Jun 19, 2007 | 03:27 PM
Default Re: (4g hatch)
i checked the grounds fuel pump is not coming n n no spark
Old Jun 19, 2007 | 05:04 PM
Default Re: (crxlsvtec01)
thanx for the replys wasnt gettin power to the ecu new jumper haness nplug pins werent seating right had to push them all in with a test light ...... but thanx everyone
JohnMumie
Jan 8, 2013 10:54 AM
kern303
Sep 11, 2012 10:23 AM
cwf1988
Jan 10, 2009 09:11 PM
white90rexsi
Jun 22, 2007 06:21 PM
md88hfcrx
Jun 6, 2007 07:12 PM
