dpfi to mpfi. resistor box need with obd1 injectors.
i need to get started on the dpfi to mpfi injector conversion. i was wonder since i have a wrecked eg. i could use th injector clips and plugs from the old obd1 harness, to do the dpfi 2 mpfi conversion. I shouldn't need to wire in the resistor box, because of the injectors being peak hold. Or is it saturated injectors...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">i need to get started on the dpfi to mpfi injector conversion. i was wonder since i have a wrecked eg. i could use th injector clips and plugs from the old obd1 harness, to do the dpfi 2 mpfi conversion. I shouldn't need to wire in the resistor box, because of the injectors being peak hold. Or is it saturated injectors...</TD></TR></TABLE>
Those injectors you have from the EG are saturdated so you won't need a resistor box.
OBD0=Resistor Box Neede
OBD1=No Resistor Box Needed
Modified by slow_rex_will at 5:43 PM 6/20/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cr-x-91 »</TD></TR><TR><TD CLASS="quote">u got it backwards bud
0bd0=resistor box
0bd1=no resistor box</TD></TR></TABLE>
QFT
If you run OBD-1 or OBD-2 injectors all the resistor box wires all need to be wired together in some fashon. You can repin them into the OBD-1 resistor box cap to keep it clean.
0bd0=resistor box
QFT
0bd0=resistor box
My Fault, Fixed it.
Blame it on the kush!
0bd0=resistor box
My Fault, Fixed it.
HiProfile
Jun 20, 2005 02:34 PM
