b16 swap wont run...HELP!!!!
Old Jun 19, 2007 | 07:07 AM
louevilhatch's Avatar
Default b16 swap wont run...HELP!!!!
Alright guys here's what is going on. I let my local shop finish my swap for me. Now when I gave them the car it had gas in it that was 4 months old and it was unleaded. Now when i got it back it ran fine. Then when i put premium in it decided to just stop running on me on the way home. Now, i dont think its the fuel pump or fuel filter cause when i try to start it up i'm getting gas to my injectors, also i can hear the fuel pump priming. when i try to start it it runs for literally 2 seconds and then shuts off. it will start but wont run...its like its not getting something. thanks much everyone
Old Jun 19, 2007 | 07:40 AM
Stray's Avatar
Default Re: b16 swap wont run...HELP!!!! (louevilhatch)
mine was doing the same thing bro. pull out ur injectors and turn the key see if they all are spraying. mine was only spraying 1 but it was because the fuel filter was old and horrible. but check your injectors they might be clogged. if they are check ur fuel filter.
Old Jun 19, 2007 | 07:45 AM
Default Re: b16 swap wont run...HELP!!!! (Stray)
thanks man
Old Jun 19, 2007 | 08:46 AM
90IntegraGS1.8L's Avatar
just because you are getting Fuel to the rail doesn't mean its enough pressure to open the Injectors. I would start with the fuel filter.
Old Jun 19, 2007 | 05:34 PM
Default Re: (Mr.P1nk)
its got a new fuel filter.that was the first thing i replaced.
Old Jun 20, 2007 | 10:55 AM
Stray's Avatar
Default Re: (louevilhatch)
since you replaced that and if it is still doing it
you need to pull the injectors out and get someone to turn the key over and watch so see if they all spray. if they dont you might have gotten them clogged from the fuel filter from before. therefore a either get them cleaned or b get new injectors. same thing happened to me
Old Jun 20, 2007 | 05:31 PM
Default Re: (Stray)
what is the best way to clean them out? sorry i've never messed with injectors.
Old Jun 20, 2007 | 07:22 PM
Default Re: (Stray)
i cleaned the injectors out and it still wont fire. i took a spark plug out and turned it over and no gas...is this normal? i did this on two of the plugs and got nothing...fuel pressure maybe?
underb00steg6
Oct 30, 2007 02:29 AM
Slyfox_racer
Sep 16, 2007 01:04 PM
RA12825
Jan 29, 2007 08:51 PM
94gsr18kid
Apr 12, 2005 05:50 PM
Backk InTheDA
Feb 24, 2005 03:52 PM
